Are these 06+ headlights legit?
Old Apr 4, 2012 | 06:18 PM
  #101
bbs350z's Avatar
bbs350z
i need a new inside plastic for my 06+...yesterday i watched my brother run over my freshly painted (drying) plastics
Old Apr 4, 2012 | 08:54 PM
  #102
BY350z's Avatar
BY350z
I absolutely love them, one of the best mods/upgrade you can do to your Z. Light output is twice as much compare to the stock 03-05 projectors and they give the car a more aggressive look in my opinion. I can post some pics of them at night if you guys want.
Old Apr 5, 2012 | 07:42 PM
  #103
Czarrr's Avatar
Czarrr
Keep the pics coming! ^
I want to get on these asap!
Old Apr 5, 2012 | 08:28 PM
  #104
13ino13's Avatar
13ino13
Originally Posted by Rouse350z
im also still trying to figure out which wire do i need to snip so the turn signals dont stay on.
Did you ever figure out which wire it is?
Old Apr 5, 2012 | 11:28 PM
  #105
PikesPeakZ's Avatar
PikesPeakZ
Man that ****ing sucks. Sorry to hear it.
Old Apr 6, 2012 | 09:46 AM
  #106
BY350z's Avatar
BY350z
You don't have to cut any wires to make the turn signal not always stay on. The easy way is to take out the bulb, look at the contacts, use a 9 volt battery with a pigtail on it as a tester and see which contacts light up the filament in question, look at the plug and harness, and cut, isolate and seal the offending wire. Heres a video to better explain it.
http://www.youtube.com/watch?v=W_IM0ugenJI
Old Apr 6, 2012 | 11:40 AM
  #107
IDrm350's Avatar
IDrm350
Do these lights have the opening in the bottom for mounting the OEM ballast?
Old Apr 6, 2012 | 04:33 PM
  #108
bbs350z's Avatar
bbs350z
^i will let you know as im ordering a set for the internals. it says its for 06+ which are all xenon, so id imagine so. the only difference im aware of as far as bulb/ballast for pre 06 lights are the fact that 03-05 bulbs are d2r, the 06+ are d2s. i believe the same wattage.
Old Jun 13, 2012 | 08:08 PM
  #109
SjC's Avatar
SjC
Will the 06+ headlight be a direct fit and plug in for the 03-05 350z?
Old Jun 13, 2012 | 09:59 PM
  #110
amr_electron's Avatar
amr_electron
Direct swap only if you already have HIDs in your car.
Old Jul 12, 2012 | 09:39 PM
  #111
Aieeeya's Avatar
Aieeeya
I bought the headlight housings from xcessmotors and they are OEM. However, after going through the trouble of removing my bumper and transferring my 2004 ballast over, I find out that the large grey cover is not the same size and the new headlights didn't come with any.
The 2004 HID ballast cover (the one with the O ring and the fins for turning) is larger than the 2006 cover. So now, I don't know how or where I can get just the cover.
Any help would be appreciated. Thanks in advance.
Old Jul 12, 2012 | 09:48 PM
  #112
-Trav-'s Avatar
-Trav-
^nissan dealer
Old Jul 13, 2012 | 04:49 AM
  #113
sluggoZ's Avatar
sluggoZ
This was explained in the DIY from member potato...go to your dealer or courtesyparts. Part#26029-CF40A http://www.courtesyparts.com/cover-h/la-p-309510.html
Old Apr 12, 2013 | 11:55 AM
  #114
OhioStyles's Avatar
OhioStyles
does xcessmotorsports still exist on ebay? cant find em
Old Apr 12, 2013 | 12:57 PM
  #115
sluggoZ's Avatar
sluggoZ
Not sure but here's their phone # 626-968-8666 9:30/5:30pm PST. M/Fri.
Old Apr 12, 2013 | 09:45 PM
  #116
Aieeeya's Avatar
Aieeeya
I bought them last year in June. Worked out perfectly! Without a doubt real Nissan lights.
Old Apr 12, 2013 | 10:20 PM
  #117
amr_electron
http://www.ebay.com/itm/OE-06-09-NISSAN-350Z-LENS-HOUSING-HEAD-LIGHT-HEADLIGHT-LAMP-LH-RH-NEW-/130778935761?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3A350Z&vxp=mtr&hash=item1e730831d1
Old Apr 12, 2013 | 10:23 PM
  #118
OhioStyles's Avatar
OhioStyles
awesome guys. I found them on there n thanx for the replies.
Justin100
Nov 25, 2021 06:26 AM
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
Viethoang91
North East Marketplace
Sep 21, 2015 01:16 PM
