Gauge Illumination wire input
Old Apr 15, 2012 | 05:56 PM
Sleeper_Z's Avatar
Sleeper_Z
Default Gauge Illumination wire input
Well I finishing up my gauge install and came across the illumination wire and wanted to confirm a question I had. I have blacked out gauges so I would assume I would need light to be constant so having the illumination wire hooked up would render my gauges unreadable unless having my lights on so with that should I just leave that wire alone or tap it into with either the 12v battery or 12v ignition source?
Thanks
Old Apr 15, 2012 | 06:48 PM
beezee's Avatar
beezee
I am not sure if I understand your question but tapping into ignition wire means there will be power only when you have your keys in the ignition position or when the engine is running. Tapping into constant 12volt provides power for as long as there is power from your battery. You could drain your battery.
Old Apr 15, 2012 | 07:43 PM
Sleeper_Z's Avatar
Sleeper_Z
The gauge has 4 wires,
Power(12v battery)
Ignition(12v when ign is on)
Illumination(12v)
Ground
Since my gauges are smoked I would need light to be constant so I would assume I either leave the illumination wire alone or "T" with one of the other 12v sources.
Old Apr 15, 2012 | 09:12 PM
R350Zz33's Avatar
R350Zz33
No you hook it the the illumination wire what brand is this glow shift ?
Old Apr 15, 2012 | 09:27 PM
Sleeper_Z's Avatar
Sleeper_Z
^Didn't really get what you were trying to say and no their Stri gauges.
Old Apr 16, 2012 | 03:05 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
thread failure. You guys cannot put together a coherent post/thought/sentence/question.
Who the hell calls it the illumination wire? You mean the purple one? The dimmer/brightness wire?
Basically what it does is when you turn your lights on the gauges dim because it is night time(or dark conditions) and you do not need as much light to see the gauge readouts and it will make your whole car glow.
Do not use the stock rheostat connection. Wont work.
Old Apr 16, 2012 | 04:26 AM
cgkp0925's Avatar
cgkp0925
Old Apr 16, 2012 | 12:40 PM
Sleeper_Z's Avatar
Sleeper_Z
What is there not to get, I have this wire and call it that because that's what they are referred to, my question is simply do I or not wire it up this particular wire as I'm not sure if it only dims or shuts power to the light. Simple really its the answers I keep getting that are not straight forward. All the rest are common sense just haven't dealt with a dimmer/light switch/illumination what ever you want to call it wire before.
Old Apr 16, 2012 | 09:15 PM
jerryd87's Avatar
jerryd87
you dont even need it hooked up if you dont want to. i dont have the dimmer wire hooked up on my dual wideband guage no need for me personally i have it set so its not blinding at night but i can still see it easily during the day.
350Z_Al
Oct 29, 2020 07:44 PM
nanotech
Oct 2, 2015 05:02 AM
