Anyone Upgrade to illuminated ignition cyl?
Old Apr 30, 2012 | 11:32 AM
bmccann101's Avatar
bmccann101
Default Anyone Upgrade to illuminated ignition cyl?
I have a 2005 Enthus and its always been a pain that theres no illumination. I dont know why its such a pain, but it just really is.
Searching around for a new clock spring, i see that the newer models have a illuminated plastic ring that goes around the cyl now.. I cant imageine that much changed to large proprietary items like the column cylinder, or the bottom plastic column cover.. but im just not sure i guess.
By the part pictures, they look simple enuff to swap over.. but..
Looks can be deceiving..
Has anyone done this? I searched and found a few dead threads asking the same thing.. no replies...or ones previous to the model year upgrade.. no help here.
Old Apr 30, 2012 | 12:09 PM
bmccann101's Avatar
bmccann101
answers, you b@stards, answers!
Old Apr 30, 2012 | 01:20 PM
bmccann101's Avatar
bmccann101
bump to the top.
Old Apr 30, 2012 | 02:23 PM
Bober'z's Avatar
Bober'z
haven't done it since my 08 already has it, but i would assume you would need a new lower cover, and the actual light ring. Have you checked if there is a plug to connect it to, or would you have to wire it somehow?
Old Apr 30, 2012 | 02:38 PM
bmccann101's Avatar
bmccann101
it looks like it uses the same part # for the lower cover and for for that trim ring.. so i just said f it and went ahead and ordered the light itself.
It will need to be wired to something of my choice yes.. can i ask you.. what triggers your light, and does it stay on always after you turn the car on? I mean its up to me what i wire it to of course, but id like to remian fairly OEM .. so im curious if ill need to hit ignition, illumination( headlights) or the dome light circuits.
Lastly, what color is the light output? Theres nothing on google image searches i have done.
thx for ur reply btw..
Old Apr 30, 2012 | 02:59 PM
Bober'z's Avatar
Bober'z
ill go to my garage right now and let you know
Old Apr 30, 2012 | 03:06 PM
Bober'z's Avatar
Bober'z
ok, heres what I got:
once you open the door the light ring comes on for 20-25 seconds and then turns off as long as the cars not started.
once you start the car the light ring turns off
when you turn the car off, the light ring lights up once the key is removed and stays on for 20-25 seconds unless you lock the car.
once you lock the car, the light ring turns off.
I hope that helps let me know if you need me to check anything else!
Old Apr 30, 2012 | 03:09 PM
bmccann101's Avatar
bmccann101
yep.. that would be the dome light circuit..
ok cool.. thank you for that. I appreciate it.
Old Apr 30, 2012 | 03:15 PM
Bober'z's Avatar
Bober'z
np, and i forgot to add that the light is orange, like the rest of the interior led lights
Old Apr 30, 2012 | 03:23 PM
Kwame's Avatar
Kwame
Different part #s for the models without the illumination ring and those with.
Old May 1, 2012 | 10:40 AM
bmccann101's Avatar
bmccann101
ordered the part from nissan.. haha.. its frikin 15 bucks.. crazy..
i had made the thread because rhdjapan sells LED ones for 150 bucks... kind of an expensive chunk of plastic to throw out of it didnt work haha.. but for 15 bones, ill report back later on when i have it all set.
Amber? Very cool.. thank you Boberz.
Old May 1, 2012 | 05:21 PM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Hmm, i wonder what else is required other than $15 worth... You get the lit ring and the undercover for that?
Old May 1, 2012 | 05:26 PM
SmoothZ's Avatar
SmoothZ
Senior Super Moderator
Okay, I must do this! Report back ASAP and let us know how it goes.
Old Jun 9, 2012 | 10:10 AM
F2CMaDMaXX's Avatar
F2CMaDMaXX
Any update on this?
Old Jun 15, 2012 | 08:06 AM
CLN350ZZ33's Avatar
CLN350ZZ33
Any updates? I'd like to do this on my 04
Old Jun 15, 2012 | 06:20 PM
STL 350Z's Avatar
STL 350Z
Updates?
Old Oct 21, 2012 | 03:22 PM
Kwame's Avatar
Kwame
I guess I was right and this doesn't work with replacing entire cover underneath the steering column???
Old Oct 21, 2012 | 03:26 PM
Tackett's Avatar
Tackett
Why not just add an led on top of it on the column so you can see?
Old Oct 21, 2012 | 04:38 PM
bonaldgonza's Avatar
bonaldgonza
Old Oct 21, 2012 | 08:10 PM
graffkid732's Avatar
graffkid732
Report back and let us know if it works please.
