Color Changing Gauges
Old May 20, 2012 | 09:11 PM
FliPPER_Z's Avatar
FliPPER_Z
Default Color Changing Gauges
Hey Guys... I already converted both front and rear turn signals into LEDs, including back up lights. Next step in the interior ...Im getting ready to tackle this project...
Im not sure if anybody has done this already but here is a video..
http://www.youtube.com/watch?v=k2K2c3QQgSA
The plan is to make something similar to that however I will do a fade into RED instead of an instant switch. Got most of the electrical problems solved except the actual signals. Im hoping somebody can explain how or what type of signal makes the rpm, speedo, etc. work. I want to create my own signal generator so I can bench test it in my own desk without disassembling my car .
Im open to suggestion ! thanks
Old May 20, 2012 | 09:16 PM
FliPPER_Z's Avatar
FliPPER_Z
this idea also came up..retrofit a universal shift light, using this as a trigger to cause the switchback?
http://www.ebay.com/itm/UNIVERSAL-11...ht_4155wt_1396
Old May 21, 2012 | 02:24 AM
JCITY's Avatar
JCITY
Color changing gauges-wow!
I've been searching for a plug in lava lamp
for my Z.Can't seem to find one.
Old May 21, 2012 | 06:25 AM
cgkp0925's Avatar
cgkp0925
I'm sure you'll find a way to make it work. Can't wait to see it on your facebook.
Old May 21, 2012 | 06:48 AM
bmccann101's Avatar
bmccann101
color changing guages are dope.. especially as the programmable OEM shift light as the trigger... I have my aftermarket gauges wired for amber illumination.. wired up relays so that it not only cuts the amber illumination but triggers the white illumination on trigger.. and that trigger can be run off the individual gauges warning output or the radar detector. i ahvent chosen which to lead it off of yet.
Far easier to see then a small flashing red led... But props to flipper for tackling it.. pretty cool. Id try to allow a circuit that allows the option of flashing switchback or static..
Old May 21, 2012 | 08:05 AM
FliPPER_Z's Avatar
FliPPER_Z
I totally forgot about our oem red LED shift light..that just made things easier! : That LED should work with a small 2.2 volt signal , enough to trigger a mosfet or transitor to cause a switchback...hmm cant wait!
Old May 21, 2012 | 08:07 AM
bmccann101's Avatar
bmccann101
yup, dont even have to disable it.. plus it remains totally programable from the OEM selector still this way.. apparently has its own built in flash as well.. from slow to fast.. id leave that as well.. and just do a switch back.. id rather not have my gauges go fully dark and flash at me versus staying the same color and simply flash to a red as it increases to the rev limiter..very cool man.. enjoy, i bet the finished product wll be great..
only issue youll have ( and let customers be aware of this) is that if they send you the whole cluster and try to drive thier car around for a week w out it.. Nissan keeps that from happening ( as the odometer circuitry is in there) by running part of the alternator circuitry thru the guage pod..
your car will start and drive.. for about 10 miles.. as it will be firing off your battery.. ask me how I know.. and why i just bought a tow hook for my car so the bumper doesnt rip off from a flat bed tow truck cable.. again.
Old May 21, 2012 | 08:43 AM
QuintonC's Avatar
QuintonC
in4resultsandpix
Old May 21, 2012 | 09:51 AM
FliPPER_Z's Avatar
FliPPER_Z
Thanks for the advice. Im ordering the gauge faces later this week from http://www.blackcatcustom.com/
I will definitely avoid the hyper flashing switching.
Old Jun 28, 2012 | 08:41 PM
TurboTom's Avatar
TurboTom
update?
really interested to see the results
Old Jun 28, 2012 | 10:11 PM
bbs350z's Avatar
bbs350z
^go back to driving your genesis
j/k i miss your g
pm user acree, he does quite a bit with this type of stuff. he used to have a z and did conversions for people, now i believe he has an evox w/ color changing gauges as well as needles.
Old Jun 29, 2012 | 04:02 AM
FliPPER_Z's Avatar
FliPPER_Z
no updates.havent had any free time.
