Painting Carbofiber!?!
Old Jan 5, 2004 | 01:08 PM
supra crazy's Avatar
supra crazy
Default Painting Carbofiber!?!
I have a carbon fiber hood that i would like to paint and leave certain spots out the probleme is that i went to 2 body shop asking them to paint it and they said they cant because the paint will chip and they cant sand the carbonfiber because they dont know what is over it. Is it posibly to paint carbon fiber without the paint chiping or is what the paint shops are telling me true because i have seen a couple of carbonfiber hoods painted.
Old Jan 5, 2004 | 01:30 PM
Chebosto's Avatar
Chebosto
you can paint it.
the hood is coated in RESIN and if its a reputable company, a gel clear coat over that..
you can paint anything. just have them treat the areas you want to paint like fiberglass- tape off the portions you want carbon still, and paint the rest. then after painting. clear coat the entire hood-
Old Jan 5, 2004 | 01:47 PM
SizongZ's Avatar
SizongZ
Sounds like they just don't want to put the work in. Especially since you say that you want to leave certain spots open. Which means they have to spray on some extra clear coat on the unpainted spots to help the lines blend better, which left undone will be left open for paint chips.
At least that is what it sounds like to me... or they just don't know what they are doing, then I would suggest finding someone else.
Old Jan 5, 2004 | 05:48 PM
drew703's Avatar
drew703
Glad this thread was started!
I'm actually get a CF wing in next week or two, and I definitely do want it painted to match. Chebosto, or anyone else who knows, should it be sanded first, or just painted like normal then clear coated?
Also, has anyone had any experience painting CF yet?
-drew
Old Jan 5, 2004 | 07:45 PM
pinnacleliquid's Avatar
pinnacleliquid
Default Gotta remember...
-drew
You are not painting Carbon Fiber. You are painting the finish that is over it. Nothing strange or exotic about it. Just prep as you would any other article about to receive paint.
Old Jan 5, 2004 | 10:26 PM
Chebosto's Avatar
Chebosto
Pinnacle is correct.. the fibers themselves are already set in resin.. you're not painting the fibers physically. you're just painting the top on the resin- i'm sure the regular way is a sand, primer, and paint with clear coat--
Old Jan 6, 2004 | 03:05 AM
supra crazy
Thanks
sp he just needs to sand then paint ?
how much do u think it should cost?
Rev_Night
Nov 7, 2020 06:00 PM
350Z_Al
Oct 29, 2020 07:44 PM
Cashwin
Oct 1, 2015 06:36 AM
