CF hood wont latch
Old Sep 5, 2012 | 09:22 AM
350zBallinout's Avatar
350zBallinout
Default CF hood wont latch
I have an 06 Z and I got a Seibon CF hood. The fitment looks great but the hood wont latch in the front. I called the guy I bought it from and he suggested adjusting the front latch. I tried to do that but it doesn't move like he said it should. Can anybody please help with this? here is a list of things on the car under the hood: 5/16' plenum spacer, strut bar, AEM CAI. Im located in Southern California in Anaheim.
Steve
310-502-8391
Old Sep 5, 2012 | 09:38 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
OEM style?
Old Sep 5, 2012 | 09:43 AM
350zBallinout
Default CF Hood wont latch
yes it is OEM style
Old Sep 5, 2012 | 09:51 AM
Z MANIA's Avatar
Z MANIA
psychedelic one
Don't force it, or it will crack the hood. I had to put 3 spacers on each side to raise the rear end of the hood before it would latch easily. Unfortunately.. I had already cracked mine.
Old Sep 5, 2012 | 09:57 AM
350zBallinout
so is there a specific type of spacer? part number? that i need to buy? easy install? i haven't cracked the hood yet, lol.
Old Sep 5, 2012 | 10:22 AM
Z MANIA's Avatar
Z MANIA
psychedelic one
I just used what was handy that I could find in my garage. I'm sorry... I'm calling it a spacer... because that was it's purpose, but they're actually stainless steel flat washers that I had lying around. You can get them at any hardware store.... cheap
edit... like this http://www.homedepot.com/catalog/pro...b63053_300.jpg
dikspiel's Avatar
dikspiel
Chestons Toilet
I would recommend getting hood latches and ditching the idea of you using the oem latch for your hood. Your seibon hood is 1 layer of carbon and 10 layers of fiberglass, I would not rely on it holding up at high speeds.
Old Sep 5, 2012 | 10:25 AM
350zBallinout
im kind of a noob to the Z world. I had an S2000 before. I like the look of the hood latches that lay flush with the hood, but i dont have the first clue how to install them.
Old Sep 5, 2012 | 10:39 AM
suprasam's Avatar
suprasam
^^ This video helped me out.
Aerocatch hood latches are awesome! If you go this route I recommend the passwordJDM mounting plate too.
http://passwordjdm.com/PasswordJDM-A...P2758C421.aspx
This video helped me with the install.
http://vimeo.com/997195
Old Sep 5, 2012 | 11:07 AM
vex008's Avatar
vex008
are you sure you loosen the latch properly? think it was two nuts that need loosening to be able to adjust it, would have to look at mine as I dont remember exactly.
Old Sep 5, 2012 | 11:10 AM
350zBallinout
i loosened the 2 nuts and it still didnt move for me.
Old Sep 5, 2012 | 06:52 PM
350zBallinout
i tried putting 3 washers on the back to raise the rear of the hood and it still wouldnt latch. i really dont wanna have to spend the money for the hood latches right now...any other ideas?
Old Sep 6, 2012 | 04:13 PM
BoomerZ33's Avatar
BoomerZ33
loosen the bolts on the hinge then pull the hood towards you and loosen the bolts on the latch then lift it upward. you may need to grab the latch with some pliers and push it forward or backward as well so it shuts firmly. these methods always worked when i used to have two different seibon hoods.
Old Sep 6, 2012 | 07:30 PM
350zBallinout
the hood wont latch...i dont understand...this crap shouldnt be this hard
BEBO'S ZEE
Jun 7, 2016 07:48 AM
EnjukuRacing
Misc.
Sep 23, 2015 07:27 AM
jdmctrek
Exterior
Sep 17, 2015 03:13 PM
Wu-Watt
East Canada
Sep 12, 2015 07:31 AM
