Need help removing shifter
Old Sep 17, 2012 | 06:24 PM
NateZ08's Avatar
NateZ08
Default Need help removing shifter
So yes, even though i have looked at some guides online, i'm still not clear on how to rotate the shift **** off. I have an 08 manual tranny. One guide says i need to clamp the part above the cotton cover under the shift boot with a pair of pliers and rotate counter clockwise. however, apparently if i do this wrong, i can royally screw up the transmission so i want to make sure i do this right. can anyone point me in the right direction?
i really just need to know how to unscrew the ****. i know how to do everything else
Old Sep 17, 2012 | 06:28 PM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
http://nissanhelp.com/diy/z/projects...ob_removal.php
Old Sep 17, 2012 | 06:34 PM
Bmurray350z's Avatar
Bmurray350z
mine was easy. took the shifter cover off, got a buddy and a big set of pliers and a rag, he put the rag in the pliers and held the shift linkage piece or whatever in place, then i simply just twisted the shift **** off with my hand. took 3 minutes.
Old Oct 11, 2012 | 04:19 PM
rcasbury123's Avatar
rcasbury123
if you have access to a lift I'm pretty sure there is a bolt that you have to loosen near the transfer case that holds the shift **** in place. after you remove it then you can undo the ****. Iv'e never done this its just what iv'e seen when i researched this so it could be wrong.
Old Oct 11, 2012 | 04:53 PM
Bmurray350z
^ yeah you're 100% wrong.
Old Oct 13, 2012 | 05:02 PM
samsniss350z's Avatar
samsniss350z
pliers/ rags, wassup with you guys, i switched mine yesterday. just pretend you're opening a jar of jelly, twist anti-clockwise, job done. screw new one on, simples.
Old Oct 13, 2012 | 05:16 PM
Tackett's Avatar
Tackett
Mine came off easy.
1.Rag around shifter.
2.Big set of vise grips.
3.clamp onto bottom of shift ****.
4.righty tighty, lefty loosey.
It's not complicated.
Old Oct 13, 2012 | 06:00 PM
terrasmak's Avatar
Transfer case?
Old Oct 15, 2012 | 09:20 AM
TPete19's Avatar
TPete19
Transfer case?
He's right on the money. And while he's got the car on the lift, he should definitely get to those muffler bearings.
You guys really need to recalibrate you sarcasmeters.
Old Oct 15, 2012 | 09:23 AM
Bmurray350z
how are you so sure he was being sarcastic?
Old Oct 15, 2012 | 10:25 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by Tackett
Mine came off easy.
+1...
Old Oct 15, 2012 | 10:46 AM
sry110's Avatar
sry110
I followed this procedure but still found my shift **** difficult to get off.
The key to not damaging your transmission is to apply equal and opposite torque on the shift lever (Clockwise direction), to counteract the torque you apply to the shift **** (counterclockwise). Even using the method in the guideline, I still managed to partially twist the leather cover off the **** before breaking torque on it to twist it off.
Old Oct 15, 2012 | 05:02 PM
amyoescobar's Avatar
amyoescobar
Old Oct 15, 2012 | 05:10 PM
Tackett's Avatar
Tackett
I was going to hold the rod, (haha haha...rod..) but when I twisted the **** to test how hard it was going to be, it popped loose.
Old Oct 19, 2012 | 12:24 PM
rcasbury123
hahaha sorry i did not mean to put transfer case i meant transmission but i did see a video where you had to undo a bolt underneath the car to be able to unscrew the shift **** but i went back and watched it and remembered it was because they were installing a short shifter, sorry for my ignorance haha
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Cashwin
Oct 1, 2015 06:36 AM
