My interior change up.
Old Oct 5, 2012 | 05:37 PM
Tackett's Avatar
Tackett
Thanks guys. Already prepping to repaint!
The momentum **** was out of stock, so I've got to find a new one.
I really like the TWM. But I can't spend that much money on a ****.
Old Oct 5, 2012 | 06:35 PM
beezee's Avatar
beezee
You may want to consider what i am doing with my amp rack. Not completly done. I will drop the amp a notch lower and add plexiglass on top. maybe some LEDs in there. The sub box slides in further than you see in the pic
Pic was taking while working on it. Generally I keep my car clean. Lol
Old Oct 5, 2012 | 07:27 PM
Tackett's Avatar
Tackett
That's pretty much exactly what I want to do with mine. Looks really tight man.
You know you can tuck that Sirius or GPS antennae under the strut bar plastic and it will still get a great signal right?
Old Oct 5, 2012 | 07:49 PM
beezee's Avatar
beezee
Yes. Thats where I hide it. I put it up there while test fitting stuff
Old Oct 5, 2012 | 07:53 PM
beezee's Avatar
beezee
A view from inside the car
Old Oct 6, 2012 | 05:02 AM
Tackett's Avatar
Tackett
Looks great!
Old Oct 6, 2012 | 04:57 PM
Tackett's Avatar
Tackett
Alrighty. So far tonight I got my shifter surround sprayed, both brake And batt covers, and both door finishers sprayed.
There's a couple of rough areas that I need to address with the old sponge sander, as well as spray some of the bigger pieces.
It takes me a long time to spray this stuff because I'm a perfectionist. I'll probably be done next weekend, depending on how much I have to end up sanding.
Old Oct 7, 2012 | 05:12 AM
Tackett's Avatar
Tackett
Just ordered an armrest pad from redline goods.
My next purchase from them in the near future will be door armrests.
Old Oct 7, 2012 | 02:03 PM
Tackett's Avatar
Tackett
The "ready for clear coat" section is growing!
Old Oct 7, 2012 | 03:11 PM
beezee's Avatar
beezee
Awesome. Hope everything come out well. If you decide to go my Amp rack route let me know. I can help with some templates. I just started the next phase. I got the plexiglass framed up and test fitted. Next I will stretch a stretchcloth over and mold them to the rack with fiberglass/filler/bondo stuff. Then I would decide whether to paint or vinyl. Some pics of the testfit and the mock stretchcloth. I will install some LEDs under them as well
Old Oct 7, 2012 | 04:10 PM
Tackett's Avatar
Tackett
Do you have a template for the whole cover? I don't need the windows, obviously, just the outer part. It would save me from a long fight with cardboard...
I love the plexiglass windows. My amps would overheat sealed in like that though. Did you put some LEDs in there?
Old Oct 7, 2012 | 05:02 PM
beezee's Avatar
beezee
Still a work in progress. No LEDs yet but I will put some in there. The cover is in 2 pieces
I realized it was easy to install and uninstall when in 2 pieces.They meet very flush and straight in the center. I can draw the outlines for you. Just cut and sand to blend. You were right with fight with cardboard. Took me lots of tries, sand and fit routines to get
a good fit.
Old Oct 7, 2012 | 05:31 PM
Tackett's Avatar
Tackett
I've been debating on painting the silver rings around the top gauges and AC controls red.
I saw a guy on here once who did that with a black interior and looked amazing.
Old Oct 8, 2012 | 09:53 AM
Tackett's Avatar
Tackett
Okay so I bought some nice PPG metal flake maroon to paint the rings with.
I took the shift boot into them and had them color match te threads. Should look NIIICE!
For my next trick ill be painting the strut bar cover black to match and the Z in the center as well as the 3 dots in each side the maroon color.
Old Oct 8, 2012 | 09:49 PM
dykel3fiddyz's Avatar
dykel3fiddyz
Originally Posted by Nismo44512
Honestly, it looks fukin retarded, but that's just my opinion.
Old Oct 9, 2012 | 03:32 AM
Tackett's Avatar
Tackett
Thanks for that invaluable contribution.
Old Oct 9, 2012 | 07:15 AM
STL 350Z's Avatar
STL 350Z
Please don't buy diamond plate floor mats.... There is nothing that looks good about them.
Old Oct 9, 2012 | 09:27 AM
  #38
Nismo350z#0310's Avatar
Nismo350z#0310
Duplicate.
Old Oct 9, 2012 | 09:29 AM
  #39
Nismo350z#0310
Now heres one fairly similar w out the JDM RSW swag ( aside from acutally being JDM itself lol) and the custom pods..
see how easily it goes together when keeping w a theme? hope this helps.
Shift boot seems to be uncircumcised in this picture.
Old Oct 9, 2012 | 05:20 PM
  #40
Tackett's Avatar
Tackett
I had an idea for them....
They are currently being powder coated black. Should turn out sweet.
