License plate bracket w/o holes in bumper
Old Dec 8, 2012 | 06:01 AM
flynzed's Avatar
flynzed
Default License plate bracket w/o holes in bumper
I picked up my ZR a couple of days ago from the dealer after the bumper incident and asked that they not install a license plate bracket on the bumper. My plan was to use the tow hook connector hole for a bumper free bracket. Here is what I came up with.
[IMG]<a href="http://s1300.beta.photobucket.com/user/cwhebert/media/100_3033.jpg.html" target="_blank"><img src="http://i1300.photobucket.com/albums/ag92/cwhebert/100_3033.jpg" border="0" alt="Photobucket"/></a>[/IMG]
[IMG]<a href="http://s1300.beta.photobucket.com/user/cwhebert/media/100_3034.jpg.html" target="_blank"><img src="http://i1300.photobucket.com/albums/ag92/cwhebert/100_3034.jpg" border="0" alt="Photobucket"/></a>[/IMG]
[IMG]<a href="http://s1300.beta.photobucket.com/user/cwhebert/media/100_3035.jpg.html" target="_blank"><img src="http://i1300.photobucket.com/albums/ag92/cwhebert/100_3035.jpg" border="0" alt="Photobucket"/></a>[/IMG]
The bolt is metric 16-20, the rubber grommets keep the plate from being pushed back at speeds and rubbing on the bumper. Is there anything I should be aware of other then the bolt connecting directly to the reinforced front structure of the car?
Old Dec 8, 2012 | 06:19 AM
tblax1624's Avatar
tblax1624
that sounds like a good idea, I believe stillen has a licence plate braket that goes in the tow hook as well?
Old Dec 8, 2012 | 06:28 AM
zswickliffe's Avatar
zswickliffe
Those rubber gromets constantly rubbing will definitely leave a mark. A little dirt gets behind them and they vibrate rapidly and the rest is history. I would make the front bracket like a TV mount with the two vertical supports on each side then bolt all four bolts on there to make sure it doesn't rotate about the x-axis at all.
Old Dec 8, 2012 | 07:47 AM
flynzed's Avatar
flynzed
I was thinking along those lines also, all though I'm not to worried about the bracket rotating, I used two lock nuts to set the depth and cranked the bracket in good and tight.
Old Dec 8, 2012 | 07:50 AM
zswickliffe
I was referring to the plate itself bending but referred to it as rotating. My apologies for not being clear. If you have an "H" bracket, you could put a screw on each corner of the H and the plate won't bend. Easy to weld, solid and completely touchless
Old Dec 8, 2012 | 08:11 AM
flynzed's Avatar
flynzed
Okay, I understand what you are referring to now. Yes, an 'H' bracket style would work nicely. Looks likes I will be doing a bit more welding. Thanks for the feedback.
Old Dec 8, 2012 | 08:14 AM
zswickliffe
Not a problem. Post pics when finished!
EDIT:
Consider heat treating the welds, too. Could be prone to cracking due to the vibrations.
Old Dec 8, 2012 | 11:33 AM
beezee's Avatar
beezee
can you post a full pic of how it looks on the car. good job
Old Dec 8, 2012 | 12:00 PM
JCITY's Avatar
JCITY
Cool Stillen L plate bracket-"no drill"
Stillen does have these.Last I saw,were around 70 bucks.I've got a buddy
that has one.The front that attaches to the plate is sheet metal or plastic about the same shape as the plate.The L plate protrudes about a qtr to half inch from the bumper surface.This distance may be adjustable.
Old Dec 8, 2012 | 01:56 PM
ocdz's Avatar
ocdz
I bought a stillen a long time ago and since have stopped using it and sold it. Pretty much the same idea as yours though.
I would do away with the rubber though, if you are that worried about screwing up the bumper to not drill it those rubber pieces will eventually do just as much damage.
Good job on the DIY action, probably a lot cheaper than $70+s/h from Stillen!
Old Dec 8, 2012 | 02:58 PM
flynzed's Avatar
flynzed
It is a bit less then the $70.00 Stillen bracket. So far I have about $10.00 invested in it.
Old Dec 8, 2012 | 10:54 PM
EmpireDude's Avatar
EmpireDude
Vendor - Former Vendor
Looks good. I love the ingenuity!As another alternative, here's what I did!
Originally Posted by EmpireDude
To actually mount the setup, I got some long threaded bolts, thin aluminum sheeting (thin as far as thickness, about 1 inch wide) with holes drilled into it. I took the license plate and frame on the ones side of our factory grill, and put the threaded bolts through the grille and then sandwiched the grille between the plate and the aluminum sheeting. With those together, I threaded the bolts on, got it straightened to where I want it and torqued them down.
It is also cool because you could put it in the center or the side (and I've done both!)
This was actually my first, uh, "mod" to my car!
Shitty little diagram, if it's helpful.
Old Dec 9, 2012 | 05:15 AM
shine-EZ's Avatar
shine-EZ
Sweet bro, im not a fan of putting my plate over the grill ( your losing cooling power) covering up your radiator and condensor is a dumb idea, Cool idea but its not functional- ill take my factory licence plate bracket until they make front plates an option!
Old Dec 9, 2012 | 07:48 AM
ocdz's Avatar
ocdz
I don't think I've ever seen your car before... any local clubs you're affiliated with?
Old Dec 9, 2012 | 12:43 PM
flynzed's Avatar
flynzed
Good idea with the modified / aluminum strap license plate bracket. I fasten my plate at the top and let it hang in front of the bumper with out any problems, however, I was also concerned about blocking air flow. Still, I like the idea and will definitely give it some thought.
Old Dec 10, 2012 | 07:16 AM
flynzed's Avatar
flynzed
Here is the completed bracket. It is a little more then 1/4" away from the bumper at the closest point. Thanks for the feedback and suggestions. I'm no welder so it's not very pretty, however, it is solid.
[IMG][/IMG]
Justin100
Nov 25, 2021 06:26 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
KOF
Tuning
Sep 30, 2015 04:09 AM
