Passenger power seat in a base help Please look
Old Dec 9, 2012 | 03:17 PM
hcenteno21's Avatar
hcenteno21
Originally Posted by Cux350z
on the connector you called out
Orange and Green are for the reclining motor power
Yellow and light blue are for the forward/reverse
Black white is the ground
Problem is that this switch is not the same as the driver side. The drivers side switches both the + and - to change motor directions where this switch provides ground signals to the controller to do the directions.
Looks like we need the controller to make this work.
what do you mean by the controller? The motor is plugged in..
Old Dec 9, 2012 | 03:19 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
That white box is the controller. Drivers side is simple compared to this. Lots of inputs to that controller
Whats the connector that is unplugged at the center bottom of the pic?
Get me the color and layout of the wires of the connector on the bottom left of the picture.
Old Dec 9, 2012 | 03:20 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
The more pics and info you give me the more i can help.
Old Dec 9, 2012 | 03:21 PM
hcenteno21's Avatar
hcenteno21
whats the colors of the wires on that loose connector on the bottom left of your pic.
Also it looks like the motor is unplugged.
We go try this two ways, splice and get rid of the controller completely or try to wire it up with the controller and jumper out some signals.
the big connector that is loose here are the colors
top
red, red with white stripe, white, blue, green w black stripe, black white stripe, black
bottom
blue, white, blue w white stripe, red, purple, purple w white stripe, green, blue w white stripe
Old Dec 9, 2012 | 03:23 PM
hcenteno21's Avatar
hcenteno21
let me know what else i can give you and again thank you
Old Dec 9, 2012 | 03:25 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
how many total pins? 14 or is does it have some blanks?
Old Dec 9, 2012 | 03:29 PM
hcenteno21's Avatar
hcenteno21
18 pin it has 2 blanks
on top between blue and green w black stripe
bottom between blue and white
Old Dec 9, 2012 | 03:33 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
that is connector B35, let me get you the pinout, give me a minute ok
hcenteno21's Avatar
hcenteno21
http://i53.photobucket.com/albums/g4...AC15EE0EF9.jpg
Old Dec 9, 2012 | 03:34 PM
hcenteno21's Avatar
hcenteno21
thank you very much
Old Dec 9, 2012 | 03:43 PM
hcenteno21's Avatar
hcenteno21
and u were right previous owner confirmed...seats are from a convertible!
Old Dec 9, 2012 | 04:10 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Some of the +12v come from switched sources.
Only connect the grounds that do not say "test without first"
I am not responsible if something goes wrong.
Some wire colors varied but only a few.
What is that other connector you showed?
Old Dec 9, 2012 | 04:13 PM
hcenteno21's Avatar
hcenteno21
the last one is the 18 pin the other one is the one that connects directly to the switch that then goes into controller
Old Dec 9, 2012 | 04:15 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
Looks like the other connector is for the heated seats, B43
Old Dec 9, 2012 | 04:31 PM
hcenteno21's Avatar
hcenteno21
i feel like we are so close!! the controller clicks now...and seat moved a tiny bit and stopped...will keep checking
Old Dec 9, 2012 | 04:35 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
what have you connected so far?
Old Dec 9, 2012 | 04:41 PM
hcenteno21's Avatar
hcenteno21
what you first said to connect...and it kinda moved and stopped right away now i tried everything else and i cant get it to do anything except click
Old Dec 9, 2012 | 04:49 PM
  #38
hcenteno21's Avatar
hcenteno21
ok i have your original suggested connection and the side switch just click but the switch on the back to fold seat works....
Old Dec 9, 2012 | 04:53 PM
  #39
Cux350z's Avatar
Cux350z
hatersgonnahate
uploaded an updated list with more descriptions/colors.
Getting close.
You may need some of the ignition signals and you may need a few off the convertible top controller signals (which are most likely ground signals and may prohibit movement of the seat)
Old Dec 9, 2012 | 04:54 PM
  #40
Cux350z's Avatar
Cux350z
hatersgonnahate
Red = Would not hook up at all
Yellow = questionable since i do not have the programs I do not know if you need the signal grounded or open
Green = confident that you need it hooked up
