Cost of Painting Door Handles Black?
Old Jan 1, 2013 | 08:23 PM
Jrockwell09's Avatar
Jrockwell09
Default Cost of Painting Door Handles Black?
Ok I know I've seen this on here before. But I'm was wondering what kind of price range I'm looking at for getting my handles done. Also I'm new to this. I've looked at a few threads before for help but just recently made an account. I was also wondering is anyone around O'Fallon MO has gotten them done where they got them done at.
Thanks
Justin
Old Jan 1, 2013 | 08:30 PM
Bmurray350z's Avatar
Bmurray350z
just go to different paint shops and get quotes
Old Jan 1, 2013 | 09:12 PM
WillyP28's Avatar
WillyP28
I paid $200 to get mine
Old Jan 1, 2013 | 09:20 PM
terrasmak's Avatar
One of the worst mods that can be done.
Old Jan 1, 2013 | 09:31 PM
Jrockwell09
Ok thanks. I have talked to a few places and most of them are telling me around $300. They say that the Z door handles are a pain to get off. I wonder if I take them off my self if it will be cheaper.
Old Jan 1, 2013 | 09:52 PM
mr. sparco's Avatar
mr. sparco
Two bolts difficult to take off? Open your door, unplug the two grommets behind the door handle and you will see two 10mm bolts. Take those off, gently pull the door handles up about 1cm from the outside, then out, done.
Old Jan 1, 2013 | 10:16 PM
flyboy9545's Avatar
flyboy9545
Like he said^^ they are super easy to get to... as for painting them... do that **** yourself its not that difficult to paint... even easier to paint small trim pieces like that. is it going to be matt? or Gloss? Just seems like a huge waste of 200 bucks to pay someone else to do it when you could do it for less than 50.
Old Jan 1, 2013 | 11:01 PM
bluelineshooter's Avatar
bluelineshooter
Is your car black?
Old Jan 1, 2013 | 11:11 PM
Sap350z's Avatar
Sap350z
I agree.
Old Jan 2, 2013 | 12:53 AM
Mcutali's Avatar
Mcutali
Default handles
those are crazy prices. not worth more than 120$. pull them out , lightly sand them, use a adhesion promotor, and you can match the paint easy at any finishmasters store. dupont chroma is best to match colors.
Old Jan 2, 2013 | 01:59 AM
logan09's Avatar
logan09
Wow it sounds like some shops are trying to make a killing off of an easy job.
Old Jan 2, 2013 | 04:37 AM
grimm66's Avatar
grimm66
Plastidip works wonders for $8 a can
Old Jan 2, 2013 | 05:23 AM
06Gcoupin's Avatar
06Gcoupin
Looks like sh*t too...for $8 a can.
Old Jan 2, 2013 | 06:17 AM
michaelm5's Avatar
michaelm5
I am sure the price quotes are high because of the cost of single stage or two stage paint. Labor cost is also high but go to your local autobody supply and inquire what a pint of paint with reducer and catalyst cost.
Old Jan 2, 2013 | 07:39 AM
ZS14RR's Avatar
ZS14RR
Paint material is cheap as fawk. 1/2 pint of black paint even 4oz will do. No more then 20 bucks. Clear coat same thing.
Why I hate shops. Trying to make a killing of something so simple. Why won't they just be efficient about it and get it done. 5 mins to take handles off. 5 mins to prep. 30 secs to spray. It's not like they have to sit there and watch it dry.
Old Jan 2, 2013 | 07:40 AM
Jrockwell09
Originally Posted by bluelineshooter
Is your car black?
No it's gunmetal grey. I powder coated the stock rims flat black and I've pretty much black everything else out.
Old Jan 2, 2013 | 07:48 AM
michaelm5's Avatar
michaelm5
Good paint, is not cheap. I would use Concept 2000. It would take a fingernail and you can rub it.
http://www.tcpglobal.com/docs/ppgdccp.pdf
You can definetely go cheaper. I would not on my car.
Old Jan 2, 2013 | 08:04 AM
michaelm5's Avatar
michaelm5
This is a cheap option and it might even be durable. At this price you could test it on an object before you used it on your car.
http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
And I agree that the shop quotes are too high but PPG, Glazurite, House of Kolor and all the other top brands are going to be well over $100 for one pint of paint material.
Old Jan 2, 2013 | 08:27 AM
NA&CH's Avatar
NA&CH
On a Black Z = one of the best mods done. If you can do without the Z. Take them out and have the shop paint them then re-install them.
Chris
Old Jan 2, 2013 | 10:26 AM
Jamin401's Avatar
Jamin401
meh plasti doesnt look to bad tbh. specially if you get the glossifier as well. hate it or love it you can always remove it. good helper if your planning on painting later on, get to see it visually.
