Any LED recommendations for interior/plate area?
Old Jan 23, 2013 | 06:45 AM
Sig24's Avatar
Sig24
Default Any LED recommendations for interior/plate area?
I'm thinking about doing an led swap on the interior and plate lights of my ZR.
Do you guys have any preffered brand or company, something available on amazon since I have a prime membership that needs to be put to use. i'm looking for something with some clarity and brightness, not really looking into colored but I'm open to suggestions from the 350z crew.
Old Jan 23, 2013 | 09:54 AM
iideadeyeii's Avatar
iideadeyeii
Cheapest SMD led for the plate(white only). I run a 4 led set-up(one layer up) I believe. Anything bigger is too long and will not fit.
For the interior dome lights I have a 3x4 SMD led (12 leds total)(white) in each side and it's very bright.
Both look much better. I picked them up off ebay for about $5 shipped for all 4 bulbs from china(took about 20 days to get it in the mail)
Old Jan 23, 2013 | 09:57 AM
beezee's Avatar
beezee
here you go if you want to help our sponsors.
https://my350z.com/forum/body-interi...de-to-led.html
Old Jan 23, 2013 | 10:32 AM
Sig24's Avatar
Sig24
Definitely going to go with them, their stuff seems perfect for what I'm looking to do. Thanks
Old Jan 23, 2013 | 11:08 AM
myork's Avatar
myork
Just keep in mind that the dome/map lights for the roadster are different than the coupe. I don't remember what they are offhand, but you should check before placing an order.
Old Jan 23, 2013 | 02:05 PM
ntwillie1's Avatar
ntwillie1
For my plates I use hoen. They r very nice.
Old Jan 24, 2013 | 07:44 PM
goracerx's Avatar
goracerx
I ordered these http://www.ebay.com/itm/360566816690...84.m1497.l2649 without removing the originals in my ZR because flea gay has a checker thing you can use by entering your car. If it doesn't fit I can use it in the truck and have A spare but would rather use them in the Zed.
Old Jan 24, 2013 | 09:14 PM
solidsnake's Avatar
solidsnake
diode all the way. easy install and look great.
Old Jan 29, 2013 | 08:01 PM
ChrisNelson's Avatar
ChrisNelson
I think if you go with a cheap LED bulb for the license plate it won't last long. The problem is that most LED bulbs are not water proof or even water resistant, and the inside of the license plate bulb housings is susceptible to moisture quite often.
I like these bulbs for license plate lighting - they are super bright and they are waterproof:
http://www.gtrlighting.com/led-light...ni-wedge-base/
AbrasiveRaysive
Sep 20, 2021 02:29 PM
350z82
Oct 1, 2015 06:25 PM
