ABS Dynamics Do-Luck Sides Fitment Issues
Old Feb 7, 2013 | 05:02 AM
sodjazero's Avatar
sodjazero
Default ABS Dynamics Do-Luck Sides Fitment Issues
I have picked up a set up ABS Dynamics plastic side skirts. Does anyone have any experience with these? Do these go over the oem side skirts? The website says direct bolt on but that does not seem to be the case..
Thanks for the help..
Old Feb 7, 2013 | 05:49 AM
Mapleleaf's Avatar
Mapleleaf
You need to take off the OEM sides and test fit these one's before doing anything
Old Feb 7, 2013 | 05:57 AM
sodjazero's Avatar
sodjazero
I have removed the OEM side skirts. They still dont seem to line up/fit to well
Old Feb 7, 2013 | 06:06 AM
Mapleleaf's Avatar
Mapleleaf
Welcome to the world of aftermarket products. Can you attach the back and front or dont they line up?
Old Feb 7, 2013 | 06:22 AM
sodjazero's Avatar
sodjazero
I can put screws in the back and the front and the middle and " make " it work with use of dremel. I just thought there was some other way i should be mounting them or any other hardware i might be needing or missing.
Old Feb 7, 2013 | 06:42 AM
Junkster's Avatar
Junkster
pics?
Old Feb 7, 2013 | 06:48 AM
Mapleleaf's Avatar
Mapleleaf
Use the OEM Hardware for the front & back and then for the sill area I had to drill and use Stainless Steels screws with a countersink washer to tighten down that area.
Old Feb 7, 2013 | 07:10 AM
sodjazero's Avatar
sodjazero
Originally Posted by Junkster
pics?
Ill see if i can get some pix tonight..
Old Feb 7, 2013 | 07:18 AM
sodjazero's Avatar
sodjazero
can you post some pix of how you have yours mounted if possible?
Old Feb 7, 2013 | 09:04 AM
Mapleleaf's Avatar
Mapleleaf
This is a old shot of the drivers door sill
Attached Thumbnails ABS Dynamics Do-Luck Sides Fitment Issues-door-sill-1.jpg
Old Feb 7, 2013 | 09:55 AM
sodjazero's Avatar
sodjazero
thanks! ill post up pics when i get a chance
Old Feb 7, 2013 | 12:56 PM
T_K's Avatar
T_K
I probably wouldn't have drilled into the chassis. That's pretty dedicated to making something that doesn't fit well, fit.
Old Feb 7, 2013 | 01:10 PM
Mapleleaf's Avatar
Mapleleaf
These did fit , except with aftermarket kits you always have to adapt something. Also the holes are filled with a sealant before attaching.
Old Feb 7, 2013 | 01:17 PM
sodjazero's Avatar
sodjazero
What sealant did you use?
Old Feb 8, 2013 | 04:05 AM
Mapleleaf's Avatar
Mapleleaf
Silicone for outdoor is good
sherm
Apr 11, 2020 05:21 PM
350z82
Oct 1, 2015 06:25 PM
samansharif
Sep 25, 2015 12:31 PM
