LED Turn Signals! (with pictures)
Old Jan 19, 2004 | 10:26 AM
ares's Avatar
ares
Veteran
Default LED Turn Signals! (with pictures)
well the new design is in. it lights up on straight 12volt current. still needs to be tested in the car. and a bit of long term testing is needed.
whats even cooler. this design is more or less identical to what would be done for the brake light. meaning that is "finished" as well.
specs:
4 batwing amber LEDs arranged around the outside. running at 225mA.
1 batwing star amber LED pointing foward, running at 200mA.
heat, it topped out at 180degrees. after about 2 minutes of being on. these are not intended to be a constant on device which is why Im not too concerned with this. but it is the reason I have to test it in the car for a while to be sure.
ok now for the pics.
price, probably around 125-150$. Im working on a better way to assemble them; but as it stands its 2-3hours of work to make a pair. if I can get it down, maybe 100$.
Old Jan 19, 2004 | 10:31 AM
MY350Z.COM's Avatar
holy crap
Old Jan 19, 2004 | 12:03 PM
afr0puff's Avatar
afr0puff
Why wouldn't they be constant on? Is it different on the Z than the G? On the G, the turn signal is lit whenever the parking lights are on, at 75%. They go to 100% when blinking.
Old Jan 19, 2004 | 01:57 PM
ares's Avatar
ares
Veteran
you sure?
but no definitly not on the Z. the Z is off unless turn signal. the parking light is seperate in the amber strip to the side.
had another one of those "setbacks". not enough clearance behind the bulb to get it in. Ill fix that somehow.
Old Jan 19, 2004 | 01:58 PM
ares's Avatar
ares
Veteran
more I think about it; Im gonna cut the power back anyway. the high output is nice; but hard to say what effect it will have on its life. the resistors will prefer it too.
Old Jan 19, 2004 | 02:21 PM
Strife350z's Avatar
Strife350z
nice work ares, they look incredible!
Old Jan 19, 2004 | 02:24 PM
DIGItonium's Avatar
DIGItonium
ahahaa.. wicked!
Okay... I'm starting to see something with my old setup. The hot glue is definitely not good for Luxeon. It melts!
Good thing I decided to move on to epoxy. (i hope)
My new design (drawn in MSPaint... ahah) is different, but I'll try to make them someday using better material.
Old Jan 19, 2004 | 07:06 PM
Phatmitzu's Avatar
Phatmitzu
Where are the white ones?!
Old Jan 19, 2004 | 07:59 PM
ares's Avatar
ares
Veteran
no white; they could be, just a matter of which LEDs used.
for brake lights Ill swap that center LED in favor of a 3 or 5watt. mmmm mmmm good.
Old Jan 19, 2004 | 09:10 PM
seanrulz's Avatar
seanrulz
Jesus Christ ares... You are really good at making people poor huh?
Sigh... I need to get my paypal account verified asap.. all my limits are gone!
Old Jan 26, 2004 | 02:33 PM
silverstoneTT's Avatar
silverstoneTT
Why not design a turn signal bulb requiring less LEDS or with a less complicated design to lower the anticipated prices?
Old Jan 26, 2004 | 02:44 PM
ares's Avatar
ares
Veteran
I can do that, but less LEDs means less light
Ive made them with 1 or 2 LEDs. but they are lacking in output.
Depravity
Oct 1, 2015 04:49 PM
