03-05 Cup Holder Replacement Problem
Old May 12, 2013 | 07:55 AM
Kooshie's Avatar
Kooshie
Default 03-05 Cup Holder Replacement Problem
Hello All,
I'm hoping someone who has knowledge about the situation can help point me in the right direction.
I recently purchased a new cupholder to replace the broken dash one I have in my 03 350z. I took everything apart in the front dash, was able to get to the screw and took out the remains of the hold cup holder and put the new one in.
However, I am still having the same problems where the cupholder is not being pushed back on its own, and a sharp/thin object is needed to pull the thing out.
Once I took out the bracket, I came to realize that the bracket that holds the cup holder was missing the spring entirely. Does anyone know the part # of this bracket with the spring or know where I could buy one from?
Your help is greatly appreciated.
-Kooshie
Old May 14, 2013 | 03:02 AM
Kooshie's Avatar
Kooshie
Bump, hoping someone with knowledge of the situation can chime in. Thanks
Old May 20, 2013 | 12:52 PM
Kooshie's Avatar
Kooshie
Bump again,
Does anyone here know what I am referring to? I would like to get this fixed and would really appreciate the help.
-Kooshie
Old May 22, 2013 | 06:17 AM
DCJodon's Avatar
DCJodon
Not sure if you can buy the spring itself, it might be cheaper to just be a completely new unit.
Old May 24, 2013 | 04:41 PM
ickis's Avatar
ickis
you should just abandon the use of this cup hold and accept it as an engineering flaw a long with the 03 third gear synchros and window motors. gl haha
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
