Track body panels inquiry
I'm going to a much more aggressive track layout than I had previously thought. I'm trying to find a set of front wide body fenders with the cutouts behind the tires, similar to the S2K in this picture:
I also would like to find a set of rear quarter panels or fenders that would be similar.
I saw a spoiler on here a long time ago that mounted to the rear of the hatch and bumper (makes the hatch unaccessible - but not relevant for purpose of car) but have not been able to find it since. It is similar to this spoiler but made completely out of carbon fiber:
If anyone has any information on this it would be greatly appreciated. I will be attempted to have my Carbon Fiber Nismo V2 front bumper remolded to fit with widebody fenders as well as obtaining a new rear bumper with a much more aggressive diffuser.
Other goals for the build will to have a light weight 18x12 or 19x12 set of wheels and some meaty street/track tires at all 4 corners. Eventually a motor swap to an RB26 now that I found the plug and play harness. Brakes and a massive suspension upgrading would take place as well. This is a 4 year goal to complete and I understand it's going to cost a considerable amount of money to get there, but I think it would be one of the most enjoyable cars I would ever own with the setup I'm looking for to complete.
If you have any information about where I could obtain the body panels and spoiler, please let me know. Thank you.
Good to know that people don't support full track setups around here....
Something similar to the Rocket Bunny FRS kit would work if I could find it.
Its going to have to be custom, and you will need to make custom side skirts. The rear bumper, that part will probably be pretty easy. Just cut it andf go from there.
I remember seeing a used Cusco 350Z wide body kit online a while back for about $3k and didn't know if anyone else actually made the parts, which is why I ask.
Serious answer is that the 350Z in stock trim can fit any spec at stock ride height. No real need for wider fenders unless like myself you want a wider appearance! Other than that it's all fluff.
That wing setup is also just for appearance...it could of been mounted several different ways...what's pictured is a very exotic way of doing it.
So you yourself have to take your plans back to the drawing boards and ask yourself...how serious is this going to go! If you feel it's going to be serious appearance is the last thing that should be on your list if not there at all...
recent track build from
https://my350z.com/forum/autocross-road/550208-the-2th-pwr-track-car-conversion.html
https://my350z.com/forum/autocross-road-305/
Also read everything in here....cause from your initial post worrying about track body panels is backwards thinking!!
your talking about wanting a track setup and downgrading to a rb26 in the same paragraph, what the **** do you expect? once you get to around 600 whp the rb26 is absolute crap for any track but the strip and below that the VQ will far outperform it with quicker turbo spool up and higher mid range so really wtf do you expect?
seriously if you had searched you would have found out you would get called a retard for that. as king said overall you have demonstrated you really arnt serious yourself, dont have much experience, and are just looking to throw money at a bunch of expensive parts and hope it works. which is a recipe for disaster
http://extremedimensions.com/03-09-3...-Body-Kit.html
PM me for insanely low pricing.
But the whole RB26 talk will make you seem kind of foolish....
https://my350z.com/forum/showthread.php?t=550208
The wing mount location I'm looking at is to limit the stress on the rear hatch/plexiglass, which has been an issue before (as I have done my research). Currently the car has a carbon fiber hatch, and mounting a functional spoiler to the top side of the hatch causes fractures and limits functionality of the spoiler itself. The rear mounted wings I have looked at in the past have proven to be more functional over a longer period of time.
I'm looking for about 450-500whp reliably with the RB26 rather than the VQ. From the research that I have done, the VQ is a pretty weak motor if you don't throw a ridiculous amount of money at it anyways. I understand the weight differences as well as turbo setups to help reduce turbo lag. This is something I have been looking into for the last 2 years now and decided that's the route I'm going to go. So thanks for your input but it's unnecessary and a waste of time.
All of that being said, I'm just going to do everything on my own and will keep it away from this forum due to the lack of support and quick draw to call names. I know the costs involved as it's in the area of $45k-$55k, but it's not your money nor is it your car. I was just trying to find the information to move along the process. Obviously, I came to the wrong place, a 350Z dedicated forum when I'm looking to highly modify my 350Z.
https://my350z.com/forum/competition...-must-see.html great person to start buying parts from.
BTW, my car is lowered and runs 18x10.5 +15 up front with 285/35-18, no crazy camber either. The rear, if I wanted , could easily run a 11.5 wheel if I had the correct offset made.
What tire sizes are you looking at ? Obviously a stagger for tires as this will be a higher HP FI car. I would re evaluate the setup. A 10.5 up front that I run will easily accept a 295 or 305/30-18 , do you need more rubber. 11.5 rear will get you a 315 up to 335 rear.
+1
Also if you search you'd noticed most the Z33 guys mount their wing on the trunk then build support stanchions on the inside!
Also 18x12 in front? What type of racing are you doing?
Either way man good luck and keep researching...this place is a great knowledge bank.
+1
+1
+1
Right now the cool thing to do is mount the wing off the rear bumper beam mounts and not connect it to the hatch at all. Then you can run it roof height or slightly higher , slightly behind the bumper and a 2D airfoil.
Tires , 335 front , maybe for auto cross , not road course.
https://my350z.com/forum/autocross-r...-my-370-a.html
No need to buy a rear bumper , look at the one in this build thread. You would just need to figure out a rear over fender.
