Removing rear windshield wiper wire and fuse
So I removed my rear windshield wiper without a problem, now I'm trying to clean it up. What's left over is the wire that led to the wiper motor and the fuse.
1. Can anyone tell me where the rear wiper fuse is, and would removing it affect my front wipers as well?
2. Where does the wiper motor wire lead to and how difficult would it be to remove it?
3. I'd also like to remove the rear wiper fluid nozzle as well as the fuse because it would be annoying accidentally hitting that and not having a wiper to clear the window.
I tried searching but didn't come up with much. I have an 07 if that helps. Thanks.
Agree with KornerCarver...
I deleted mine over a year ago and did the same thing. Although I found that running the motor wire through some small pipe insulation helped the wire from tapping against the hatch. Just a little FYI incase it comes loose from the tape in hot to cold environments.
The fuse IS a part of the main wiper motor if I am not mistaken so simply plugging the end of the fluid line and then sealing it with some silicone should suffice.
Are there any guides on here going through a water pump removal, I didn't see one. If not, is the process pretty simple? That's exactly what I want to do. How long did it take you bud
I also plan on removing my rear wiper nozzle today. Did the wiper delete a couple months ago, and now its time to get rid of that pesky nozzle spray😅. Think instead of taping the hose to my hatch, I'll try to remove that entire hose piece, it seems like if I put a screw at the end of the hose and tape it...that something could possably go wrong when/if I accidently go to use my rear wiper lol and water gets filled in the hose and something bad might happen!!??
Move inner fender well to the side, pull plug to water pump, make sure you pulled the proper plug. There are two pumps, one for the front , one for the back.
350Z_Al
Oct 29, 2020 07:44 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
