Anyone vinyl wrap their interior ceiling?
Old Aug 15, 2013 | 04:20 PM
billyvq_uick's Avatar
billyvq_uick
Default Anyone vinyl wrap their interior ceiling?
I saw the thread on how to remove it, I was just wondering if a vinyl would look good? My concern is that vinyl won't be able to sit plush along the curves of the ceiling?
Old Aug 15, 2013 | 04:30 PM
David_2613's Avatar
David_2613
I did it on my 325i and I wasn't happy with the result. I wished I had just used standard ceiling felt, which I had used twice before.
Old Aug 15, 2013 | 05:34 PM
trapp1829's Avatar
trapp1829
i think vinyl would end up showing every little imperfection on the ceiling. I ended up using black suede and recovered mine
Old Aug 15, 2013 | 05:43 PM
mattleegee's Avatar
mattleegee
paint it with vinyl spray paint
Old Aug 15, 2013 | 05:54 PM
freddys 350z's Avatar
freddys 350z
i did...i think it would come out smoother if it was painted first..all the little imperfections show through.
and the area around the sun visors is tricky.
Old Aug 16, 2013 | 01:32 AM
billyvq_uick
Ok thank you all for the responses. The reason I asked is because the design I was looking for appeared to only be in vinyl, but I found some in a fabric.
Old Aug 16, 2013 | 09:35 AM
David_2613's Avatar
David_2613
For a smooth finish w/ least amount of work, you will want the fabric to have some sort of foam backing to hide imperfections in the liner.
I've done it with straight felt and it took a lot of prep and cleaning to achieve a bump and wrinkle free finish. The foam backed type is more forgiving and takes a lot less prep work.
Old Aug 17, 2013 | 01:33 PM
billyvq_uick
thanks for the advice. i'm not sure if this fabric i'm looking at comes with a foam backing option. i wonder if i could just buy thin sheets of foam separately instead?
Old Aug 17, 2013 | 01:48 PM
mcubed45's Avatar
mcubed45
Just buy regular headliner material. Apply as usual then put your fabric over that.
Old Aug 17, 2013 | 02:40 PM
terrasmak's Avatar
Just plastidip it, seems to work for everything else
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
