Sylvania headlight kit
Old Aug 22, 2013 | 06:16 PM
dcains's Avatar
dcains
Originally Posted by KornerCarver
Just about any auto detailing shop will polish headlights. I would suggest taking your car to a pro and let them polish the headlights. I suspect they will get them looking like new.
Agreed - you need to quit before doing any more damage. Let a pro take it from here.
Old Aug 23, 2013 | 01:37 AM
bender's Avatar
bender
Originally Posted by lilchief
Should I just try to Polish my headlights and see if it works? If so what Polish to use? May and aluminum is for metal surfaces right?
You didn't really need a kit to begin with. Just wetsand (start with a 2500 grit or 2000 depending how bad it is) and go up in grit (up to 3500) to get the surface nice and smooth for polish.
Hazing is normal until you buff the headlights with some polish. If the surface isn't smooth enough, you're not going to get that hazing out.
Old Aug 23, 2013 | 08:17 AM
lilchief's Avatar
lilchief
The surface seems smooth and why I was wondering if I should just try and polish it? Just not sure what polish to use.
Old Aug 23, 2013 | 03:56 PM
BranZ's Avatar
BranZ
Your kit didn't come with a polish?....
Old Aug 23, 2013 | 06:46 PM
dcains's Avatar
dcains
I just looked at the Sylvania kit on Amazon. It's crap. First, the sandpaper isn't fine enough, with it going up to only 2000 grit. You need 2500, then 4000 to get the surface ready for polish, and you need to use lots of water during the process. Second, you've got to polish by hand with that kit, which is useless on such a damaged surface.
Get the Mother's kit, which I mentioned a long time ago in this thread. It has a foam polishing "ball" which is used with a power drill. Used properly, you will get a mirror-smooth, clear finish, but first use some 2500 and 4000 grit wet-dry sandpaper (remember, lots of water) to repair the damage you've already done. Protect your paint with lots of tape.
Mothers PowerBall 4Lights Headlight Restoration Kit : Amazon.com : Automotive Mothers PowerBall 4Lights Headlight Restoration Kit : Amazon.com : Automotive
Old Aug 25, 2013 | 10:47 PM
ParanoidAndroid's Avatar
ParanoidAndroid
4000 isn't needed...my body shop wetsands with 1000 then 1500 and uses a medium cut rubbing compound and buffs them out. They charge $50 to do this and they come out brand new.
Old Aug 28, 2013 | 09:56 AM
lilchief's Avatar
lilchief
Still haven't fix it I spoke with a expert detail shop here they said they gonna come to my place and do both headlights for 80 bucks.... Sounds right? Also can I wash my car meanwhile? It won't make it worst right?
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
JGee450
Sep 30, 2015 04:32 AM
