Anyone replace the Top Parking lights on a 06 Headlight?
Old Oct 17, 2013 | 03:29 PM
GUz33's Avatar
GUz33
Default Anyone replace the Top Parking lights on a 06 Headlight?
Has anyone changed the top parking lights on an 06 Headlight?
I know theres a direct replacement for those but what I mean is soldering new LEDs to it.
Old Oct 17, 2013 | 04:32 PM
Qtip350z's Avatar
Qtip350z
I have replaced mine but you have to open up the whole headlight and build a piece to mount the led's to (see pic below) If you go this route I would suggest you use only the highest quality led's as i did not and now have to rip my headlight apart and do it all over again. Got 2 years of good use and now half of them are dead!
Old Oct 17, 2013 | 05:45 PM
mcubed45's Avatar
mcubed45
doesn't somewhere sell them as a unit with the led's soldered to a board?
Old Oct 17, 2013 | 05:49 PM
SeczDBZ's Avatar
SeczDBZ
http://zledslights.com/?page_id=1421...43&id=21415243
You're welcome.
Old Oct 17, 2013 | 07:15 PM
taywan's Avatar
taywan
Those look pretty good but I Dont run those nor the top park either. I only run the lower park and of course signal.
Old Oct 18, 2013 | 05:55 AM
GUz33's Avatar
GUz33
I know you can get the direct replacement ones. I just wanted to know if anyone just soldered new ones in. Just wanted to see how they did it.
Thanks for the link for the direct replacement! those are cheaper than the ones I saw. they were like $45 But ill order from there if things don't go how I would like it to go.
my headlights are currently opened already Im just waiting on the LEDs to come in.
The ones im going to replace it with will be 5mm white leds
Old Oct 18, 2013 | 05:57 AM
GUz33's Avatar
GUz33
Qtip350z did you desolder the LEDs from the back of the circuit board? first time doing this kind of circuit board.
Old Oct 18, 2013 | 02:53 PM
Qtip350z's Avatar
Qtip350z
I made a new board made of abs plastic the same size as the existing board and mounted 4 flush mount led's in to the new abs piece! It worked really good but my led's are cheap and started to die one by one after about a year I will replace them with good quality led's next time i open up the headlights!
norrix420
350Z Roadster
May 23, 2022 05:11 PM
Dsowe
Feb 17, 2021 10:38 AM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
samansharif
Sep 25, 2015 12:31 PM
