Racing Seat Install Confusion
Old Dec 18, 2013 | 07:57 PM
JDM_35OZ's Avatar
JDM_35OZ
Default Racing Seat Install Confusion
I'm going to ordering a pair of Corbeau FX1 Pro seats for my 350Z but I had a couple questions I could not find the answers too.
Do I need BOTH brackets and side mounts to install the seat or just the brackets and sliders.
My Z is a 2003 Touring with the power/heated seats, I was wondering I'm going to be running into any issues with the install because of that.
Thanks in advance!
Old Dec 18, 2013 | 10:09 PM
sidewaysil80's Avatar
sidewaysil80
bracket, sliders, rails per seat. (unless fx1 are bottom mount too, then you can forgo seat rails)
Old Dec 19, 2013 | 01:31 AM
JDM_35OZ's Avatar
JDM_35OZ
Okay thank you!
Yeah they're bottom mount. I'll just be ordering them with the brackets and sliders then. Thanks!
Old Dec 20, 2013 | 12:12 AM
terrasmak's Avatar
You will get an airbag light, I tried many resistor combo's and could not get it to go out.
Old Dec 20, 2013 | 02:26 AM
NOLAGG's Avatar
NOLAGG
The 370z uses a 2.2 ohm 1/2 watt resistor for the light not to go on . You tried everything and nothing ?did you actually take an ohm meter and see what it puts out first ?
Old Dec 20, 2013 | 02:47 AM
terrasmak's Avatar
That's what I used, shortly after I just removed all the airbags and wiring.
Old Dec 20, 2013 | 04:00 AM
thekinn's Avatar
thekinn
I disconnected the negative terminal on my battery before disconnecting the seat wiring and no airbag light. But.. the airbag didn't work either.
Old Dec 20, 2013 | 05:31 AM
NOLAGG's Avatar
NOLAGG
I will be doing this soon , so you guys took an ohm meter and measured the resistance correct ? And it's 2.2 as well?
3vilbunny
Jul 18, 2017 05:10 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
