Foggy/yellow Headlights 2003 350z Track /w HID
Hi,
My 350z headlights are foggy and yellowish. I bought a "restoration" kit by Sylvania, but before I started I noticed it won't help since a lot of it is actually on the inside of the lenses.
My car is equipped with Xenon HIDs from the factory (that still work great) and I just need the headlight assemblies. What do you recommend?
Thank you
Thank you
Check out YouTube for DIY's....many different ways to do this, and all input so far is dead on....it's not on the inside, easily restored to like new with some elbow grease and patience, but if you sand toooooo much you can take off the UV protection and then you'll have to redo them every few weeks (so I've read..haven't seen that one play out in real life personally)...I've used toothpaste and elbow grease...works but can take multiple passes to get good, but another set I had to work on needed more than toothpaste, a rag and elbow grease so I used a cheap rotary buffer from Harbor Freight to work the toothpaste around...that set still needs a sanding though..was pretty cloudy and resistant to polishing....when using a buffer just gotta use common sense and tape off the paint of your vehicle.
YouTube though....you'll be all set.
Saved
Saved
VQ35DES
Nov 24, 2003 07:54 PM
hokiemax
Sep 15, 2003 01:03 PM
SKiDaZZLe
Jul 31, 2003 10:47 PM
