370Z fog light switch
It appears they are the same. If the blank on the 350 is retained the same way as the switches are then it should work. I can't find a good picture of the back of one of those fog light switches though.
If you have found where to buy them I want one (if they fit)
I think most, if not all, Nissan switches are all retained the same way. Even if it wasn't, it's not hard to fabricate something to make it hold in place (i've even seen people use hot glue since it's easily removable). The only thing i'm concerned about is the actual size of the switch (width and length).
You can purchase them here:
Rear Fog Light Harness & Illuminated Switch, 09-14 370Z
I'm not sure if Nissan would sell just the switch...but I could definitely use the whole harness for my project.
Yea, I know I could install a generic toggle switch, but....it doesnt look good enough for me. I also thought about buying the UK indicator stalk...but I think that requires quite a bit of custom work to get the fog switch to function independently.
I have a mini 3 position switch poking out under the console just in front of the seat. Black switch and black interior. You don't notice it unless you're looking. But if I could get the rocker that would replace the blank that would be much better.
