Help! front & rear emblem
Old May 23, 2014 | 08:38 AM
jodieuler's Avatar
jodieuler
Default Help! front & rear emblem
Does anyone have this emblem on there car? If so how does it look and what did you do to fill in the holes?
Old May 23, 2014 | 09:12 AM
Feedmebearzilla's Avatar
Feedmebearzilla
I do looks pretty good IMO
Old May 23, 2014 | 09:13 AM
jodieuler's Avatar
jodieuler
Could I see a picture please!
Old May 23, 2014 | 09:17 AM
Feedmebearzilla
I'll post it up later I'm at work at the moment but I only have it in the front since I have a roadster
Old May 23, 2014 | 10:18 AM
Don1376's Avatar
Don1376
Your front and rear bumper has holes under emblems? My '06 didn't when I changed my emblems. Just strong double sided tap that I used Goof Off cleaner to clean the remaining sticky glue the tape left behind. Peeled backing off tape on new emblems and stuck them on. My side emblems had holes but new emblems had tape and pegs to go thru them to help line them up.
Old May 23, 2014 | 05:58 PM
jodieuler's Avatar
jodieuler
Do you know if an 05 has holes under it?
Old May 23, 2014 | 06:33 PM
Don1376's Avatar
Don1376
I couldn't say for sure but I believe only sides and rear has holes to help line them up. The front one is reseast a little so it'd be hard to not get it straight. Also if there were holes the double sided tape on the new emblem would seal over the holes. The tape is only thing that seals holes on sides and back of original emblems
Old May 24, 2014 | 05:36 AM
KornerCarver's Avatar
KornerCarver
The coupes have two holes in the trunk under the emblem. The roadster does not have holes. If you have a coupe, you will have holes unless a previous owner had them filled. There are no holes under the front emblem.
Obadabot
Jun 18, 2023 11:31 PM
