Tow Hook?
Old Aug 11, 2014 | 11:40 AM
BigBlue's Avatar
BigBlue
Default Tow Hook?
I got a new front bumper cover recently and now the tow hook threaded hole on my '07 is very visable; no louvers to basically hide it like on my stock cover. I could get a black metal or plastic "plug" and it would look much better, OR what do some of you think about getting a good aftermarket tow hook? I see Zs that keep the hooks in place and I think some look pretty cool. That would take care of the hole issue, but don't want to catch Sh*t either haha!
Old Aug 11, 2014 | 11:44 AM
DmanG281's Avatar
DmanG281
I ride around with this one myself.
Amazon.com: Sparco 01612RS Red Tow Strap: Automotive Amazon.com: Sparco 01612RS Red Tow Strap: Automotive
It isn't overly showey because 9 times out of 10 it is pushed back into the bumper area. You will need to buy your own bolt though. You can get size info online. But for a little less than 20 bucks I am happy.
Pulled out
Pushed In
Old Aug 11, 2014 | 12:14 PM
BigBlue's Avatar
BigBlue
Thanks, but I would want to utilize the stock threaded tow hook hole. For example, I had even looked at these and others on Amazon there are variety of colors; don't want to spend like $200 for a Moon Face; I'd put a piece of electrical tape over the hole if I had to!
http://www.amazon.com/s/ref=nb_sb_ss...tomotive%2C369
Old Aug 11, 2014 | 12:29 PM
DmanG281's Avatar
DmanG281
Yep. That is bolted in the stock threaded tow hook hole. I just got the appropriately threaded bolt from Amazon and bolted it in. There are 3 different sized bolts oddly enough depending on year. A quick search here will net your correct size.
16mm x 45mm Class 10.9 Flange Bolt (2 pieces): Amazon.com: Industrial & Scientific 16mm x 45mm Class 10.9 Flange Bolt (2 pieces): Amazon.com: Industrial & Scientific
Old Aug 11, 2014 | 02:30 PM
BigBlue's Avatar
BigBlue
I see now how that works, thanks. Yeah I think '03-'04 are 16mm, '05-'08 are 22mm.
Old Aug 11, 2014 | 07:36 PM
NoQuestionZ's Avatar
NoQuestionZ
I would cover it and hit it with some black paint. I know I was adamant about not getting a tow hook until I went to the track. I would remove mine in between track days if it didn't look so cool (and if I didn't have to take the bumper off to get it off!)
Old Aug 11, 2014 | 08:00 PM
BigBlue's Avatar
BigBlue
what type do you have, any pic?
Old Aug 11, 2014 | 10:02 PM
NoQuestionZ
I can't remember the brand. I know it's not some big name expensive one. I don't think I track hard enough to NEED a legit tow hook. I used the OEM one for the first track day I went to but took it off since it sat like / and rubbed on the underside of the bumper.....
Here is a picture of my tow hook.
Old Aug 12, 2014 | 05:40 AM
stogey420time's Avatar
stogey420time
Club Moderator
the Hot Spot
Looks like it's the AutoTecknic tow hook. I agree about removing the tow hook between track/car show/meet days... strictly for looks imo.
Old Aug 12, 2014 | 07:23 AM
BigBlue's Avatar
BigBlue
thanks, that looks good on your car. Did you have any clearance issues with the actual hook section and your bumper cover when screwing it in?
Old Aug 12, 2014 | 07:54 AM
pyshin's Avatar
pyshin
My vote is for hiding it with some paint.
Old Aug 12, 2014 | 08:10 AM
iideadeyeii's Avatar
iideadeyeii
Just paint the crash bar flat black
Old Aug 12, 2014 | 08:49 AM
BigBlue's Avatar
BigBlue
^yeah, that makes sense. I think I'll just use black paint to hide it; may look for a small plug to keep threads clean that can be removed by hand in case I need to use stock tow hook, which hopefully I won't. Thanks guys
Old Aug 12, 2014 | 11:55 AM
NoQuestionZ
Yep I had to pull the bumper cover off to install it, therefore it stays in all the time even though there is no track day booked
roadmax
370Z Roadster
Aug 5, 2021 08:01 PM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
350z82
Oct 1, 2015 06:25 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
