Steering wheel air bag removal
Old Nov 10, 2014 | 06:22 PM
iPwN's Avatar
iPwN
Default Steering wheel air bag removal
Hello 350z Owners,
So i recently bought a NRG quick release steering wheel setup and got instructions from my350z.com in the DIY section. Somehow the torx 30 air bag screws that hold the airbag stripped when i tried to unscrew them by hand. Is there a easy solution to removing them.
Thank you,
Old Nov 10, 2014 | 06:46 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Short answer is NO. How badly are they stripped?
Old Nov 10, 2014 | 07:00 PM
iPwN's Avatar
iPwN
its stripped a pretty good amount.
Old Nov 10, 2014 | 07:46 PM
Bmurray350z's Avatar
Bmurray350z
Let me just tell you, you are in for hell. I stripped those torx bolts as well. It was a complete nightmare removing those things. Here's what you will want to try and do first:
-Cut a slit in the head of the bolt with a dremel and use a flathead
-if that doesnt work, go ahead and cut up the plastic piece behind the airbag because you'll have to at this point. then try and get a really good vise grip on the bolt and turn.
-if that doesn't work, then do what i did, drill through the head of the bolt.
good luck! i'll pray for you. you're about to experience some very frustrating times.
Old Nov 19, 2014 | 10:37 AM
gabez33's Avatar
gabez33
by any chance do you a good replacement bolt? what size is it?
yea those TORX screws with their soft metal are hell
Old Nov 19, 2014 | 11:45 AM
dkmura's Avatar
dkmura
While I dislike taking any thread OT, let's hope anybody trying to take out airbags has disconnected the battery and drained the electrical system. Nothing like having your head right next to an explosive device you're trying to work on.
Old Nov 26, 2014 | 12:41 PM
aboveliquidice's Avatar
aboveliquidice
Exact same *uckin thing... Be very careful when you drill them out. I had my wife on stand by to call 112.
Old Nov 28, 2014 | 06:36 AM
terrasmak's Avatar
Quality tools and there is no problem with them. If you have a quality driver and know how to use it, they will not strip.
