LED strips for DRL
Old Sep 12, 2015 | 06:20 PM
Mw870's Avatar
Mw870
Default LED strips for DRL
anyone tried using LED strips to replace the reflector's on the stock front bumpers? I only managed to find one person who had posted about it but have had no luck contacting them and I can't seem to find kits or any information on a DIY. And yes I did try google, the best I found was some useless videos showing them off nothing informative
Old Sep 12, 2015 | 06:47 PM
mr. sparco's Avatar
mr. sparco
Diode Dynamics IIRC retrofits LEDs into reflectors, try contacting member jhc. I've couple a few on ebay. I made my own using genuine Philips DRL LEDs and they are extremely bright.
Old Sep 13, 2015 | 01:36 PM
ridered929rr's Avatar
ridered929rr
Damn those are bright
Old Sep 17, 2015 | 09:09 PM
g3rard's Avatar
g3rard
Lots of LEd strips on ebay for cheap. Here's another nice setup-https://my350z.com/forum/body-interior-exterior-and-lighting-diy/550328-leds-on-350z-side-markers.html<table border="0" cellpadding="0" cellspacing="0" width="92"><tbody><tr height="21"> <td style="height:15.75pt;width:69pt" height="21" width="92">
</td> </tr></tbody></table>
Old Sep 18, 2015 | 03:27 AM
jhc's Avatar
jhc
General & Tech Moderator
I did not do a writeup cause there are already several.
White markers from Z1, $60. Bake in full size (not toaster) 5min at 250F. Let cool, then crack open w putty knife. Drill a 3mm hole for wires.
Silicone is better than superglue for led strip from Diode Dynamics. Clamp for 1 hr. (Superglue fogged the 1st one i did, had to open it back up and clean the inside w acetone). Reassemble and seal w silicone.
3M connectors for power from the small, low bulb inside headlight, comes on with park lights. Reinstall fender liner. gl, I'll find a pic for you.
Old Sep 18, 2015 | 03:49 AM
travlee's Avatar
travlee
Master
good ol ebay mods......
Old Sep 18, 2015 | 03:56 PM
Mw870's Avatar
Mw870
thanks jhc looks great and very bright, I'm thinking of just running them onto a rocker/toggle switch to use up the free space next to my heated seats buttons.
Old Sep 19, 2015 | 02:38 AM
jhc's Avatar
jhc
Even better. Good luck with your project. btw if you have a helper to pull the pass side fascia out, you do not have to remove your windshield washer tank. Def recommend that option. A mini right-angle phillips rachet is helpful also.
Old Oct 1, 2015 | 04:20 PM
_bit's Avatar
_bit
hm, id like to see the markers opened up with the LED strip
Old Oct 2, 2015 | 03:17 AM
jhc's Avatar
jhc
Close.
Using vinyl tape to clamp while silicone sets.
Old Oct 2, 2015 | 08:23 AM
dcains's Avatar
dcains
This is a closeup of how I did mine:
Result:
350z82
Oct 1, 2015 06:25 PM
dcains
Sep 21, 2015 09:28 AM
