Attempted break in. How to fix?
Old Nov 20, 2015 | 11:39 PM
robbyj's Avatar
robbyj
Default Attempted break in. How to fix?
So looks like some low life scum of the earth has taken to my key lock with a screw driver in an attempt to break in.
Does the whole handle need replacing? Does a new lock have to be fitted/cut to fit my key.
Thanks in advance.
Rob
Old Nov 21, 2015 | 04:50 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
That blows I would think that just a new lock cylinder would do it but most will be a different key. I would call a locksmith and see what they can do about salvaging that lock cylinder.
Wonder why they didn't just go through the window like a normal scumbag.
Old Nov 21, 2015 | 05:28 AM
Cux350z's Avatar
Cux350z
hatersgonnahate
Do you use your key in the door?
Buy a USDM handle and swap..that may work.
Or cut the two wires on the window switch that go to the key cylinder.
slayer9008
Oct 13, 2018 03:57 AM
350z_87
Drivetrain
Mar 9, 2016 10:10 PM
AJLUVHERZ
Jan 26, 2016 05:01 PM
SoCali-Z
Nov 24, 2015 01:33 PM
phelannz
Nov 20, 2015 05:32 PM
