Exterior Door Handle fix problem
Old Nov 19, 2015 | 11:04 AM
phelannz's Avatar
phelannz
Default Exterior Door Handle fix problem
Hi there, I bought a 2004 Base Z for a reasonably cheap price ($6000USD) with the idea of fixing up a couple of minor problems and then selling it again. I like it so much though that I'm using it as a daily driver and don't want to give her up!
There's a couple of small problems that I've been dealing with. I changed the head unit and took out the clunky old GPS unit as well. I replaced the AC and Alternator belts. Today's mission is to swap out the broken Exterior passenger door handle, and to do a window motor reset on the drivers side door.
Anyway - I got the replacement part for the left hand door (which here in New Zealand, is the passenger door) but it was shipped from the USA, which meant is was for the drivers side door which has a keyhole on it. Now I have a keyhole with no lock. I can't find the part that I'm looking for, and Now I'm thinking it's probably better to just get a lock that doesn't actually connect to the locking mechanism - just to blank it off. Which part will I need to do this? - I can't find it on Amazon. The broken piece of the old door handle is connected to the entire exterior frame, so I can't just chop and change the pieces and make a working handle out of the old one. Frustrating!
Here's an album. http://imgur.com/a/r6pXh
Old Nov 19, 2015 | 11:35 AM
dcains's Avatar
dcains
Nissan isn't going to make a specific part to block off that lock cylinder hole, why would they? You'll probably have to fabricate something on your own, and try to find some paint to match, or maybe just paint it black to contrast the silver. You''ll probably be the only one to notice it.
Old Nov 19, 2015 | 12:13 PM
phelannz's Avatar
phelannz
I meant to buy a key cyclinder for the door and just not connect it to anything. I think the best thing to do is just find the outer cover of a key cylinder and just glue it to the inside of the handle.
Old Nov 19, 2015 | 12:52 PM
dcains's Avatar
dcains
Can you disassemble the two assemblies to make one complete assembly using the old part without the key hole?
Old Nov 19, 2015 | 12:53 PM
Syner's Avatar
Syner
http://www.courtesyparts.com/auto-pa...-cat/door-scat
also...
frilly socks!
Old Nov 19, 2015 | 01:03 PM
phelannz's Avatar
phelannz
They're just folded over gym socks, I swear!
Old Nov 19, 2015 | 01:07 PM
Syner's Avatar
Syner
lol sure
You can get the part numbers you need off Courtesy's website. They are relatively expensive, but at least you can search for exact part numbers on other sites rather than part descriptions.
Old Nov 20, 2015 | 05:32 PM
RWDBajan's Avatar
RWDBajan
www.eBay.co.uk. UK Z's have the right door handles. That's where I got mine.
orot2
Nov 6, 2015 09:34 AM
CWDings
Nov 2, 2015 05:26 AM
bangbang001
Wheels Tires
Oct 24, 2015 05:03 AM
