Sponsored by:
Sponsored by:
Sparco seat problems
Old 05-15-2016, 06:20 PM
chatcher
chatcher's Avatar
Default Sparco seat problems
I am trying to install Sparco R333's. I have them in now the issue is they sit too high. I have tried Megan's seat brackets and NRG's brackets. The NRG is lowest for the driver and the Megan is for the passenger. However they are not low enough (esp the pass). I have sliders on and would like to keep them. I am wondering if there is something out there that is much lower or should I be looking for someone local to customize what I already have.
Thanks for any help in advance
Old 05-15-2016, 11:41 PM
armt350z
armt350z's Avatar
The passenger side is a nut roll, there are no off the shelf options to fix that side. Go custom.
Old 05-16-2016, 04:32 AM
AdvanZ33
Senior Super Moderator
AdvanZ33's Avatar
I used Sparco bases and sliders with my R100s and the bases seemed to be as low as possible without touching the floor. After looking at the R333 I think your problem may be the thickness/height of the seat cushion rather than the base. Ultimately, I think you may need to lose the sliders or choose a different seat IMO.
Old 06-04-2016, 03:58 PM
chatcher
chatcher's Avatar
Had the brackets custom welded lowering them quite a bit cost more than the brackets but now I can fit with a helmet and the pass seat looks immensely better.
chatcher
04-05-2016 05:31 PM
zectasy
12-10-2004 11:29 AM
ninjajubei
05-21-2004 09:24 PM
ninjajubei
350Z Roadster
05-18-2004 12:54 PM
Quick Reply: Sparco seat problems
