Trunk not fully closing?
Old Jun 15, 2017 | 08:52 AM
sebby_z33's Avatar
sebby_z33
Question Trunk not fully closing?
So recently I just noticed on my 350z the trunk seems to be popped up just a tiny bit. It fully opens and closes perfectly but while it's closed it has a very slight increase. Almost as if something is stopping it from closing completely. The other day I was with my buddy, he has a red 350z and he pointed it out to me and then I was able to see the difference in comparison... Any suggestions or ideas?
You can slightly see the displacement above the right tail light. Hard to see, this is the only picture I have at the moment.
Old Jun 15, 2017 | 10:15 AM
Atreyu'z 350's Avatar
Atreyu'z 350
When it's like that and you push down on it, does it go down flush where it's supposed to and pop back up like that, or does it stay like that?... And I mean gently/normally push it down, not hulkmode it...
Old Jun 15, 2017 | 12:52 PM
sebby_z33's Avatar
sebby_z33
It doesn't go down I lightly closed it and it just looks like this. Not sure if it's normal but it is more raised than my friends 350z.
Old Jun 15, 2017 | 01:01 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Looks like it might be slightly bent. That can happen if an object on one side of the trunk was trapped and pushed the rear hatch up on one side.
Old Jun 15, 2017 | 01:04 PM
sebby_z33's Avatar
sebby_z33
I'll have to check when I get home from work but I think it's like that on both sides, not major noticeable but still a slight issue. Thanks for the reply though! I'll check later tonight.
Old Jun 15, 2017 | 01:23 PM
dcains's Avatar
dcains
I'm going to bet one/both of the hatch struts are installed with the bottom mount upside-down. Did you install new ones lately?
Old Jun 15, 2017 | 02:21 PM
Atreyu'z 350
Ok. You lightly closed it. When you did that, did you hear the FIRST click? There's supposed to be TWO clicks till fully closed.
Old Jun 16, 2017 | 11:21 AM
travlee's Avatar
travlee
Master
those swirl marks would drive me crazy
Old Jun 17, 2017 | 05:43 AM
sebby_z33's Avatar
sebby_z33
I just got the car it's still new to me, what do you recommend? I was going to take it in and get it buffed/waxed/polished, but still not sure.
Old Jun 17, 2017 | 05:44 AM
sebby_z33's Avatar
sebby_z33
When I got the car it was like that, but the owner included two new ones I found them in the trunk. Thanks for the reply man
Old Jun 17, 2017 | 07:34 AM
dcains's Avatar
dcains
So, was that the problem?
Old Jun 17, 2017 | 07:39 AM
travlee's Avatar
travlee
Master
i would do a full paint correction
Old Jun 17, 2017 | 10:14 AM
Atreyu'z 350
Old Jun 17, 2017 | 09:19 PM
sebby_z33's Avatar
sebby_z33
Didn't try it yet, got home from work late. Tomorrow I'm changing my break pads i'll look into the hatch struts. If that doesn't work, i'll be sure to update you.
Old Jun 18, 2017 | 05:35 AM
dkmura's Avatar
dkmura
Brake pads...otherwise you look the fool.
Old Jun 18, 2017 | 07:11 AM
sebby_z33's Avatar
sebby_z33
I was too tired last night, thanks homie
Old Jun 18, 2017 | 09:32 PM
sebby_z33's Avatar
sebby_z33
How much would that cost on a Z? Just a full restored black paint job..
Old Jun 18, 2017 | 11:22 PM
dcains's Avatar
dcains
Take it to a good detail shop and ask them if it's even a candidate. You need an adequate amount of paint thickness, and depending on how bad the paint is, it could be $200 - maybe even $500.
Old Jun 19, 2017 | 03:04 AM
travlee's Avatar
travlee
Master
this... and it is hard to say how much, geographic location and amount of correction needed will determine the price. luckily my detailer is not very mechanically inclined so i helped him do coils on his car he did paint correction on my car
Old Jun 19, 2017 | 11:01 AM
sebby_z33's Avatar
sebby_z33
I tried looking online, and I know every location is different. I saw posts that were saying a paint job would cost around $3,000-$5,000. My paint isn't too bad theres no rust, maybe a scratch here or there, from a few feet away you wouldn't see any flaws; only up close. I live in Oswego, Illinois if that helps.
