Need help aligning new headlights.
Old Nov 28, 2017 | 10:44 PM
Karlo Terrones's Avatar
Karlo Terrones
Default Need help aligning new headlights.
Im very confused, I think I may have faulty HID bulbs but the majority of light is coming from the drivers side, the passengers side is sorta emitting just two ***** of light. Also the line that the drivers side headlight is producing, isnt straight. Now, the ceramic cathode thing sorta broke during installation in the passengers side headlight, would that be why its mainly producing two ***** of light?
Old Nov 29, 2017 | 08:52 AM
Heel Til I Die's Avatar
Heel Til I Die
Are these OEM or aftermarket?
A few things/tips: 1) the cutoff line should not be a straight horizontal line. It should be stepped. This is on LHD in order to prevent blinding oncoming traffic. On RHD models, the step is flipped. 2) If the light output is not uniform and there are noticeable “*****” of light, it’s likely the bulb is not seated correctly. 3) if the cutoff and flicker is not as sharp as you would like it, then the projector lens probably needs to be spaced or adjusted.
I’m not sure what cathode thing you are referring to, but make sure you are using the correct bulbs as well. For instance, D2S as opposed to D2R.
Old Nov 29, 2017 | 09:44 AM
Karlo Terrones
Uhh, they're technically aftermarket I suppose, but I specifically went for OEM style ones, I can link it here. I was wondering if that step was intentional so thank you for clearing that up. That must mean that the bulb that was damaged is messing up the conformity.
The blue ceramic tube thing is what I''m referring to as being broken, it cracked and isn't one whole piece anymore.
What I purchased.
Old Nov 29, 2017 | 09:51 AM
Karlo Terrones
Also, is there another gear that I can turn to adjust them? I only see one and it adjusts up and down.
Old Nov 29, 2017 | 10:21 AM
travlee's Avatar
travlee
Master
try this how to
http://www.hypersprite.com/auto/tech-z-003/index.asp
Old Nov 29, 2017 | 10:28 AM
Karlo Terrones
Yea I've tried that one. I think it may be that one of my bulbs is damaged so my light is uneven.
Old Nov 29, 2017 | 10:58 AM
travlee's Avatar
travlee
Master
or... it isnt seated properly. where did you get the bulbs from?
Old Nov 29, 2017 | 11:07 AM
travlee's Avatar
travlee
Master
if they are cheap ebay bulbs, it may be part of the problem. i would at minimum get morimoto bulbs
https://www.theretrofitsource.com/hi...-d-series.html
Old Nov 29, 2017 | 11:44 AM
Atreyu'z 350's Avatar
Atreyu'z 350
You might have the horizontal adjustment ****, and you might not. I do; but some oem housings won't. You'll have to see if yours do. Here's the location.
Old Nov 29, 2017 | 05:51 PM
Heel Til I Die
The ***** of light are generally referred to as "hotspots." These are typically caused by the bulb not being seated correctly. A more atypical problem could be some type of deformity in the projector bowl, but that is less likely.
If you think you messed up the bulb, try swapping bulbs from one side to the other. If the messed up light pattern follows the swap, then the bulb is the culprit.
+1 on Morimoto bulbs from TRS if you don't go with the OEM Philips. Since you're using the 03-05 housing, the D2R is the correct type, but I believe you can use D2S as well. The main difference between the two is the narrow strip on the D2R.
Old Dec 7, 2017 | 03:17 PM
mcubed45's Avatar
mcubed45
I'd start with getting better bulbs. The matsushita ballasts are known to not work well with non-oem bulbs (anything other than phillips or osram). Morimoto is the only non-oem brand recommended by TRS.
