Is my headlight toast?
Old Dec 22, 2017 | 09:09 AM
TristanZ's Avatar
TristanZ
Default Is my headlight toast?
So I recently painted the inside of my headlights black & all was fine and dandy for a while until my passenger side HID went out. Took it out just now & there's a small amount of water inside. Dumped it out & drying it off right now, crossing my fingers that I don't have to go out & buy a new headlight. When it's completely dry I'll take the bulb out & test it in the other light & vice versa to see if it's just the bulb or the ballast. How resistant are the ballasts to water? For those who have attempted this DIY, what's the best way to reseal the lights? I baked the old glue but I guess that wasn't enough. Thanks & pray for my light!
Old Dec 22, 2017 | 12:39 PM
KornerCarver's Avatar
KornerCarver
Do you have your fender liners installed?
Old Dec 22, 2017 | 02:19 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
You don't see the answer in your own statement??
Butyl adhesives are the only/best way to seal them correctly. NEW butyl adhesive.
Old Dec 26, 2017 | 08:13 AM
TristanZ's Avatar
TristanZ
​​​​​​​Yes I realize that I'm asking whether the ballast is completely ruined.
On that side, no I didn't. When I did my headlights I was too tired & hungry by the end that by the time I had the bumper & other fender liner in I said screw it I'll do it over the weekend. It's so frustrating to take this car apart without a jack. I got all the water out & used my heat gun to evaporate whatever water was in my ballast & it works good as new. Will reseal when I get another day off. Thanks guys.
Old Dec 27, 2017 | 06:48 AM
yosip1115's Avatar
yosip1115
Ballast is toast, bulb is resistant. Just had an issue the other week that caused water to get into my housing thru the vent port. Swapped the ballast and the bulb was fine. Good luck
DBZ
Jan 16, 2005 09:40 AM
rummya87
Dec 23, 2004 07:25 PM
hfm
Jun 12, 2003 05:47 AM
