Rocket Bunny Diffuser Fitting
Old Apr 16, 2018 | 01:29 PM
Strudul's Avatar
Strudul
Default Rocket Bunny Diffuser Fitting
Anyone fitted a Rocket Bunny diffuser? Trying to work out how to go about mounting, especially the centre section.
Spats (side bits) are presumably a simple case of bolt / rivet to the bumper, but the centre section is pretty heavy and I'm not sure how best to attach it or what to.
Cheers
Old Dec 26, 2018 | 07:15 PM
FairestladyZ's Avatar
FairestladyZ
Default Rocket bunny diffuser
Did you find anything on making brackets bro havrbt found any?
Old Dec 28, 2018 | 08:37 AM
Strudul's Avatar
Strudul
Found a few solutions. Most seem to just bolt to the bumper then hang the front edge with a bit of metal or builder's strap, but this seemed a bit weak.
Couple guys I talked to made full frames to mount to, which is definitely the best way, but lots more work and weight.
I bolted to the bumper, then ran 2 rods down to the front edge, with tie rods to the subframe, secured in place with nuts, which seems like a good, strong compromise. Only issue is that if you bottom out, it may take the boot floor with it, as it's only thin.
Cjw4050
Mar 3, 2023 07:08 AM
sage_lee
Dec 26, 2018 07:16 PM
stein350z
Oct 14, 2014 04:14 PM
isy_nismo
Jun 12, 2014 09:36 AM
Rodizzle
Feb 23, 2013 11:51 PM
