Aftermarket headlights help
Old Sep 7, 2018 | 01:05 PM
cyukio's Avatar
cyukio
Default Aftermarket headlights help
Ran into some problems need a little help. I just purchased some headlights and it arrived today but when i went to out them on it seems that my connector is bogger than the connector on the new headlight. Its a newbie question but i cant just buy headlights for the year of my Z? Or does it have to be specific?
Old Sep 7, 2018 | 01:28 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Difference: 2003 to 2005 models had EITHER Halogen lights OR Xenon HID. 2006-2009 models all had a Bi-Xenon HID setup. The lights you just got are probably 6-pin Halogen for use in the earlier model.
FYI, the more desired lights ARE the 2006+ lights which your car already has. Why are you replacing the headlights? If from damage, they'll need replacing. But if it just that the lenses are crazed (also foggy, scratched, basically wonked), they can be polished and rebuilt OR if replacement is necessary, your two choices are OEM or DEPO brand. The rest are essentially garbage.
Old Sep 7, 2018 | 01:50 PM
travlee's Avatar
travlee
Master
Replacing for swag points from buddies
Old Sep 7, 2018 | 03:14 PM
cyukio's Avatar
cyukio
One side is super foggy to the point that i cant see the signal bulbs
Old Sep 7, 2018 | 03:25 PM
Freise's Avatar
Freise
Wet sand with 600, 1000, 2000, ++ then polish it and it will be better than new. Hit it with some good UV protection monthly especially if it isn't garaged
Old Sep 7, 2018 | 05:14 PM
Heel Til I Die's Avatar
Heel Til I Die
If you can't return the headlights you just bought and don't feel like wet sanding, you can always swap the lenses. A little more work than polishing them, but another option.
jlam5
Nov 1, 2017 07:17 PM
vodka
South East Marketplace
May 8, 2013 12:09 PM
ecorona6
Southern California
Sep 27, 2005 09:14 AM
Nominee
Jun 3, 2004 07:13 PM
