03 350z base headlight swap to 06+ HELP
Old Jun 1, 2019 | 08:52 AM
Elias Lopez's Avatar
Elias Lopez
Default 03 350z base headlight swap to 06+ HELP
I need help guys. I've searched about the headlight swapping. And I decided to switch the 8 pin connectors on the headlights to a 6 pin for a direct plug and play. But no luck, when I connected them. All I got was the drl on, not even the turn signal would work. Is there any more wiring that I have to do for the swap to function??
Old Jun 1, 2019 | 03:29 PM
Heel Til I Die's Avatar
Heel Til I Die
I think you did it backwards assuming you are going from base/halogen to HID. You need to change the 6-pin harness in your Z to 8-pin for the HID '06+ headlights.
In all honesty, I guess you could change the 8-pin HID headlight harness to 6-pin, but you would need to do more wiring and essentially be grouping the turn signal, parking light, and side marker together.
Old Jun 1, 2019 | 03:53 PM
Elias Lopez
Oh damn so I went backwards on it. But I read a few converted to the 6 pin, but now I'm lost on what other wiring I need to do
Old Jun 1, 2019 | 04:40 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Easiest way to convert 6-pin (Base model Z) to ‘06+ HID:
https://rover.ebay.com/rover/0/0/0?m...2F333199264966
Plug n’ play.... just as easy as pre-‘06 HID to new Bi-Zenon.
Old Jun 2, 2019 | 04:23 AM
Heel Til I Die
I made this a while back when I was doing a retro. This is from the 2005 FSM, so the colors may be different than your '03, but hopefully the pinout is the same.
View is looking at harness from vehicle and NOT looking at the harness on the back of the headlamp!
LH = Left hand or Driver Side.
RH = Right hand or Passenger side.
Wire color:
B = Black ========
W = White ========
R = Red ========
G = Green ========
L = Blue ========
Y = Yellow ========
BR = Brown ========
PU or V (Violet) = Purple ========
GY or GR = Gray ========
1: Turn signal, power + (LH: G/W; RH: PU/W)
2: Headlamp High, power + (LH: R/Y; RH: BR)
3: High/Low Headlamp, ground – (LH: B/W; RH: B/W)
4: Turn signal/parking light/side marker, ground – (LH: B; RH: B)
5: Side Marker/parking light, power + (LH: R/L; RH: R/L)
6: Headlamp low, power + (LH: R/B; RH: R)
1: Turn signal/parking light/side marker, ground – (LH: B; RH: B)
2: Turn signal, power + (LH: G/W; RH: PU/W)
3: Headlamp High, power + (LH: R/Y; RH: BR)
4: Headlamp High, ground – (LH: B/W; RH: B/W)
5: Side marker, power + (LH: R/L; RH: R/L)
6: Parking light, power + (LH: R/L; RH: R/L)
7: Headlamp Low HID, power + (LH: R/B; RH: R)
8: Headlamp Low HID, ground – (LH: B; RH: B)
Old Jun 5, 2019 | 04:21 PM
mcubed45's Avatar
mcubed45
Wow that's awesome. For anyone that's into DIY, I made my own using these for about $50:
https://www.wiringspecialties.com/ge...nector-female/
https://www.wiringspecialties.com/se2rbcoincof.html
Old Jun 5, 2019 | 05:06 PM
MicVelo's Avatar
Between your molex source and Heel’s wiring chart, done and done.
I’m just lazy and would probably waste the extra $40 to save time. 😆
Old Feb 26, 2020 | 03:33 PM
Dcook14's Avatar
Dcook14
awesome, thanks
Old Mar 24, 2020 | 01:28 PM
Grrrrrnader's Avatar
Grrrrrnader
Default What I bought was a 6 pin to 8 pin converter
What I ended up buying was a 6 pin to 8 pin for my depo headlights . I haven’t installed them yet . But I took a gamble and hope everything ends up working out . And if you guys have some insight on this please message me ! I could really use the help
Old Mar 25, 2020 | 03:21 AM
Heel Til I Die
You should be fine. Where did you get them from?
If you run into any problems, you can troubleshoot using the pinout diagram above.
350zEric
Southern California
Jan 30, 2015 05:49 AM
ovalnegri
Feb 5, 2011 08:01 AM
lav350z
Sep 9, 2009 01:49 AM
ecorona6
May 12, 2005 08:09 AM
