Speedo Casing Replacement
Old Apr 6, 2020 | 12:03 PM
Osakakev's Avatar
Osakakev
Default Speedo Casing Replacement
Hi,
I need to replace the casing on the speedo clocks as its pretty beaten up. Mine is a 2006 rev up but will the casing from other years also fit?
Cheers
Old Apr 6, 2020 | 03:06 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Search is your friend:
https://www.ebay.com/itm/Nissan-350Z...sAAOSwEnZa3kd7
Old Apr 6, 2020 | 10:39 PM
Osakakev's Avatar
Osakakev
Thank you.
I'm not in the US so it's easier for me to buy a new unit and just use the bit I need
Are all the years the same or do I specifically need to buy a 2006 one?
Cheers
Old Apr 7, 2020 | 05:14 AM
dkmura's Avatar
dkmura
I believe that it's the same casing for all years, but that only applies to USDM models. For JDM or euro-spec Zs, you'll need to do additional research to be sure. If you go to your local UK Nissan dealership, they should be able to order the part for you. But be prepared for high cost of buying an OEM part at retail pricing.
Old Apr 7, 2020 | 05:16 AM
Osakakev's Avatar
Osakakev
Great, thank you!
Bornatubby
Mar 25, 2010 08:17 AM
Cannysage
Southern California
Jan 17, 2007 07:43 PM
clemlover15
Sep 21, 2006 08:09 PM
