2006 350z Front Will Fit On the Rear??
Old Mar 24, 2010 | 10:38 PM
Bornatubby's Avatar
Bornatubby
Default 2006 350z Front Will Fit On the Rear??
Hi, i stuffd up my rear rim, guttered it pretty bad. so im plannin on getting one from the wreckers. they have a FRONT 2006 350z Rim thats in great nick.
Would i be able to put it on the rear??
I know its SLIGHTLY smaller, but can you really notice?
And most importantly. WILL IT FIT:?
TA
Old Mar 25, 2010 | 03:50 AM
Bornatubby's Avatar
Bornatubby
Someone gimme a reply?????????
-__-
Old Mar 25, 2010 | 04:03 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Yes it will fit but since it's not the same width as a rear rim, the tires will look different.
Old Mar 25, 2010 | 04:16 AM
AcidJake75's Avatar
AcidJake75
Living in 350Z
Cleaned up thread.. Geez guys - simple answer would have worked.
OP IIRC - the 06 have 18x8.5 rears and 8.0 fronts. you CAN put the front on the rear but I hope its just temporary and not permanent cause it WONT look right.. Tire size depends as well..I think you can go 235 or more on a 8 inch rim
Old Mar 25, 2010 | 07:02 AM
scotts300's Avatar
scotts300
You can make it "look" right with a spacer. The rears are 18x8.5 +33 and the fronts are 18x8 +30 (or maybe I have the offsets reversed - look on the back of the wheel). If I'm right on the offsets, putting the front 18x8 on the back would require a 3mm shim spacer to have the face of the wheel sit at the same spot as the 18x8.5. It's not ideal, but I bet no one would notice.
Old Mar 25, 2010 | 08:17 AM
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
reno56
Interior
17
Nov 20, 2015 05:21 PM
nissan1310
Oct 12, 2015 08:54 AM
RyansZ33
Sep 15, 2015 05:54 AM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
lolsupfoo
Sep 9, 2015 12:57 PM
