alum trim on steering wheel removal...
Old Feb 26, 2004 | 07:32 AM
FB-350's Avatar
FB-350
Default alum trim on steering wheel removal...
Anyone know how the alum trim pieces on both sides of the horn are removed?
i checked and noticed there is a philips screw on the backside of the steering wheel which seems to secure those alum. trim plates on - i got the screw off, but didn't want to yank the alum. piece too hard in fear of breaking something....
an isometric would be ideal...
thanks.
Old Feb 26, 2004 | 07:35 AM
BRZ33's Avatar
BRZ33
Hmmm, good question..
Old Feb 26, 2004 | 04:57 PM
silverstoneTT's Avatar
silverstoneTT
I was wondering the same thing. Also, Jeff or Jason, can these pieces be purchased or would a person have to order a whole new steering wheel?
Old Feb 26, 2004 | 06:05 PM
CatastrophZZ's Avatar
CatastrophZZ
well if it was screwed in and still not removable, that means that it have the quick snap thingy... fasten plugs?!?!
Old Feb 26, 2004 | 06:52 PM
alphared's Avatar
alphared
looks like it's just held in by clips. Unscrew and pull.
Old Feb 26, 2004 | 09:53 PM
ACP's Avatar
ACP
perfect timing on this post
I am going to take mine off, to see if I can install my GReddy overtake boost botton on the left side....
Let me know how you make out
Old Feb 27, 2004 | 03:17 AM
FB-350's Avatar
FB-350
attempt #2 this weekend....
Old Feb 29, 2004 | 10:13 AM
FB-350's Avatar
FB-350
update:
attempt #2 unsuccessful...man i pulled and pryed - nothing..
short of sticking a screwdriver in and prying it off that way - i've got a feeling there may be something else holding it in place...
anyone else have any success???
Old Mar 1, 2004 | 06:16 AM
ACP's Avatar
ACP
FB-350 will bump this post, as I would like to know as well....
Old Mar 1, 2004 | 10:06 AM
Abomination's Avatar
Abomination
In alphared's post the diagram looks like it shows two items (screws, bolts???) directly behind where the aluminum plate on the steering wheel is. Very close to the steering colum itself, anyone see if a screw is on the oppoisite side yet?
Old Mar 1, 2004 | 02:51 PM
alphared's Avatar
alphared
Maybe this diagram could help.
From the Service Manual:
Disconnect battery for aleast 3 mins
Remove the two bolt (torque bolts, 4-10 ft-lb when putting it back on)
Disconnect 2 connectors (Airbag and Horn/Cruise, i think)
This way you can get a better look at what's holding the aluminum trim.
Old Mar 1, 2004 | 03:24 PM
FB-350's Avatar
FB-350
thanx alphared - i had removed the caps covering those bolts and considered removing them, but i didn't want to get in to messing with the horn/airbag housing...
ok so attempt 3 this weekend.. i need to get a torx type head for those bolts....
Old Mar 2, 2004 | 02:35 AM
OP Z's Avatar
OP Z
I believe the service manual calls for a special tool, not a torx wrench. I looked into doing this a while back and gave up when I came across the special tool requirement.
Old Mar 8, 2004 | 04:14 PM
FB-350's Avatar
FB-350
next time i bring my car for service, i'll ask the service guys...
(both have 350's and one has the stillen s/c on his...)
to be updated soon...
Old May 23, 2004 | 05:00 AM
ACP's Avatar
ACP
anyone figure out how to remove this ?
Old May 23, 2004 | 09:58 AM
ZZZealous007's Avatar
ZZZealous007
some CF replacement peices would be awesome.
Old May 28, 2004 | 01:27 PM
pinnacleliquid's Avatar
pinnacleliquid
bump
Old May 28, 2004 | 03:54 PM
rockshox's Avatar
rockshox
If someone is willing to loan me these pieces I would love to make some carbon fiber overlays for them. I have been thinking about a set for quite a while
Old May 29, 2004 | 05:36 PM
ACP's Avatar
ACP
I finally took mine off
I took the screws out on the back of the steering wheel
Then on the lower part of the wheel, I took out the 2 Security Tork screws #2 & #4 in the diagram above (they are size TX30)
The the center section comes off.
You will see to torque screws, holding on the wheel,remove them
Then.... there is one last screw, hidden at the bottom, below the wires in this picture, that you have to take out, and then the whole wheel will come off.
Then one screw holding on the aluminum trim piece
rockshox, you are welcome to mine, as I tried to make a hole in mine for a button, and failed bad.
But you could use it for the shape still
I ended up ordering the left steering wheel controls from the FX, as they are the same as the z.
I am going to use the mode button, for my overtake boost button.
Will post back with pictures, when I install it
Here is the wheel off now
Old May 30, 2004 | 09:41 AM
Colorado S14's Avatar
Colorado S14
Wow involved.
P.S. I hope that you are not dangling the airbag system by just those wires that scares me.
