Windows, mirros, locks not working
Old Jun 23, 2025 | 12:08 AM
Umer209's Avatar
Umer209
Default Windows, mirros, locks not working
Hello everyone I hope you guys are doing great, so I have a 2006 nissan 350z touring Rev-up. The issue i am facing is that both windows are not going down or up. I have changed the window motor on driver side but still no result. checked the wires and power is there. I do not know what to do. Please help. I have searched everywhere and have found no solution even after going through about 5-10 forum posts. The real answer is not there. Any help would be appreaciated. Thank you.
Old Jun 23, 2025 | 06:41 PM
icer5160's Avatar
icer5160
One of your window switch modules might be bad. If one switch goes out, it will disable both sides. I believe the same is true for the door locks. This symptom can also occur if you have a break in the wiring/circuitry between the doors.
Also note: When you replace window motors, you need to re-calibrate their stop positions.
Good Luck!
-Icer
Old Jul 3, 2025 | 04:23 PM
Umer209's Avatar
Umer209
Thank you for your reply. So I tried swithcing the swtich module but nothing happened so I am going to swtich the wiring with new ones and see if that helps and i hope it does.
Zendem
Jun 8, 2021 12:30 PM
engiman34
350Z Roadster
Jun 27, 2017 04:23 AM
ruban
Dec 17, 2013 03:35 PM
pr0xx
Feb 26, 2012 01:53 PM
Wmnengr
350Z Roadster
May 11, 2007 05:16 AM
