how to adjust headlight
Old Apr 2, 2004 | 05:41 PM
Z33@TOR's Avatar
Z33@TOR
Default how to adjust headlight
Please help...i want to raise the headlight up a little bit because it's so low now...anyone know how?
thanks
Old Apr 2, 2004 | 05:50 PM
spdu4ia's Avatar
spdu4ia
I'd like to know this as well. also Z33@TOR were can i find more pics of your car?
Old Apr 2, 2004 | 05:51 PM
mucky's Avatar
mucky
You need a long phillips head screwdriver. here is a little gear to the inside and back of the light case. It's hard to describe. A flashligt also helps,even in the daytime.
Old Apr 2, 2004 | 06:18 PM
35oZephyR's Avatar
35oZephyR
Your manual illustrates this pretty well too...
You're not looking for a phillips nut or anything like that...it's just a little hole with a spinning disk that has big teeth. Kind of like a sprocket. A 10'' phillips will do fine with turning that disc.
Make sure you're staring at a wall with the headlamps on when you do this. Just an inch of adjustment can mean a huge difference!
For kicks I turned it up all the way and drove around the block at 3 in the morning. My headlights were pointing into people's bedroom windows. It has a very wide range of adjustability.
Old Apr 2, 2004 | 07:04 PM
Z33@TOR's Avatar
Z33@TOR
i tried but it's really hard to turn the gear thing
and which direction should i turn?
Old Apr 2, 2004 | 08:27 PM
spdu4ia's Avatar
spdu4ia
i tried to turn mine and no go... fenderwell isn't commin out either now that i put the springs on it. i cant even get a 10" philips in the hole. any ideas?
Old Apr 3, 2004 | 01:44 AM
35oZephyR's Avatar
35oZephyR
I believe it's clockwise to go up and counter to go down. It was hard for me at first but believe me...those gears have to turn a whole lot before you see any big difference.
Old Apr 3, 2004 | 01:49 AM
35oZephyR's Avatar
35oZephyR
You know...it seems like a lot of trouble but just head to your local home depot and grab some of the screwdrivers they have. Bring em out and try em all. Keep the one that works and return the rest. Hell you could even return the one that works after you use it. The "Husky" brand that I bought and kept ...you don't even have to take out of the package to use.
Some screw drivers are too thick to go down the shaft or two thin to spin the gears. So you kind of have to find the right one. I used a (labled on grip): "683-366 R HD" Husky if that helps. I'm sure theres not much science too it but this particular phillips worked perfect.
Old Apr 3, 2004 | 02:45 AM
slay2k's Avatar
slay2k
I did this before this thread even started... and noticed that my headlights are now higher but they seem weaker... anyone else notice that ? If they point higher, they seem to have less of a range for some reason.
Uriyo_
Sep 8, 2021 08:46 AM
Dsowe
Feb 17, 2021 10:38 AM
JGee450
Sep 30, 2015 04:32 AM
