Replacing front lights
Old Apr 3, 2004 | 05:57 PM
cquence 350 [Z]'s Avatar
cquence 350 [Z]
Default Replacing front lights
Does anyone know the easiest way to replace the front turn signal bulbs and the parking lights without taking the front bumper off? I think the easiest way is under the fender well. If this is so should I take off the wheels or can i squeeze through fine?
Old Apr 3, 2004 | 08:58 PM
xsmallpaulx's Avatar
xsmallpaulx
it is easier if you take your front wheels off. under the wheel well are little black fastners that look like buttons undo all of them and the plastic under cover will come off and you can get to your lights
Old Apr 3, 2004 | 09:05 PM
ares's Avatar
ares
Veteran
you can do it without removing the wheels. you do *kinda* have to jack up the car. 1 guy did it without jacking up the car but I think he said it was a PITA.
if you jack it up you get lots of clearance in there(have to jack it up, ramps wont do) then remove the 2 screws and 3 fasteners.
check the DIY forums, I did a writeup in there with pictures.
etkms
Jun 19, 2022 06:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
seagrasser
Oct 11, 2015 03:27 PM
