Where/How Did You Mount Your 4/5 Point SeatBelts??
Got my Takata yesterday
Having problem finding a place to mount it. The fisheye wont fit the factory seatbelt bolting place, and I cant find a place to bolt my lap belts...
Anyone equiped with a 4 or 5 point seatbelt please help me out.
Thanks!
Thanks!
I drilled & tapped the factory bolt holes to accept the eye bolts. It took about 10 minutes
Thanks!
Thanks!
first off I have a seat belt bar that bolts into the back(for sale sold car PM for it $90 bucks) and I had all others in the following
lap belts - bolted to current belt base by the door and to current seat belt uhhh attatcher releasey thing.(just took off the plastic cover and bent little tabs...
crotch belt I wrapped around the seat mover bar and had no issues at all...
-non
-non
Alright, I got it done. I bought 4 Sparco Harness Reinforcement Plates ($2 each).
Bend 2 of them in 90 degrees, drilled a hold to bolt thu the seating bolts. Then bolt on fisheye onto the plates...
For the shoulder belts, I just mount them onto the factory speaker frames. Heres it with out the cover...
30 min job. Im happy now...
Sorry, my camera sucks...spent all my money on you know where.
I guarantee they will not allow it... thats why I had the bar made so that I could bolt it to the frame... I mean it works great for drivin around everyday ( not the safest) but any track will decline... do it right the first time.... I would only suggest this if you arent going to the track but then again why would you have harnesses then...
-non
-non
-non
-non
BTW Mr B, how bout local drifting events? will they allow it?
" I hate the harness bar...it totally blocks the rear view."
I don't know your height, but my harness bar (mounted straight across between the OEM shoulder belt bolts) doesn't block the rear view AT ALL! It appears below the rear strut bar when viewed through the rear view mirror.
Now, the view out the RR quarter window is reduced by about 1/2.
Using the sub bracket as a mount is strongly not recommended. The shoulder belts should be mounted less than 10 degrees from horizontal to prevent spinal compression in a crash.
Good luck!
Good luck!
what about under the rear carpet right behind the seat? there is a threaded hole already on mine. that way the belt goes over the divider behind the seat and almost horizontally through the headrest?
i ordered a sparco 3-point and i was planning to use that hole.
Good luck!
Good luck!
