Tail lights not working
Old May 2, 2004 | 07:25 AM
Cra Z's Avatar
Cra Z
Default Tail lights not working
well i got my system installed at " AL & ED's " and my tail lights and the 3rd brake light arent working. Does anyone know what could be wrong? i checked the fuses but they all seemed fine....... any help would be appreciated because i would rather fix it myself rather then leave it at the place for a day.
Old May 2, 2004 | 08:31 AM
ares's Avatar
ares
Veteran
sounds like a fuse. and you probably didnt check the right one.
it will be in the battery compartment, but not the easily visible one.
remove the shrouding over it(not just the cover, I mean pull the rivets and remove the shrouding) and theres another one behind the battery, that has alot of light fuses.
make sure you check all the fuses in front of the battery, and in the drivers footwell too, Id check them all first... incase it is one of them. but its probably in that other one, most lighting fuses are in there.
Old May 2, 2004 | 06:52 PM
Cra Z's Avatar
Cra Z
um ok i tried looking under the battery cover and i only found ONE set of fuses.... that black cover. Please help me find the other ones im having trouble... any pictures that can help ? thnxx
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
