removing sliding cupholder
Old May 14, 2004 | 12:32 AM
code350z's Avatar
code350z
Default removing sliding cupholder
anyone know how i can remove the cup holder. spilled some coffe and now it's all sticky...ewww! thx
Old May 14, 2004 | 01:05 AM
ether's Avatar
ether
its easy, when you pull it out on the top is a groove.. use a flat screw driver push it in until it stops then gently press it down. this will release a tab. use a small amount of pressure or else you will break the tab.. it does not require a lot of force .. but if you do break it its only about $35 to replace.. I'll post up a pic of the service manual to help explain
Old May 14, 2004 | 01:15 AM
ether's Avatar
ether
ok here is the pic.. use the screwdriver where the red arrow is.. yes its not how the service manual says to do it.. but having taken it off i say its the easiest way of taking it off.
File Type: bmp
Old May 14, 2004 | 01:21 AM
ether's Avatar
ether
here are the official instructions.. I suggest going through the top.. the manual says to go through the bottom..
you decide
File Type: bmp
Old May 17, 2004 | 08:23 PM
FLZ's Avatar
FLZ
Default curious
you decide
Not trying to be a smart-as*, just wondering what you'll do with the square hole left after removing the cup holder?
Old May 17, 2004 | 08:31 PM
ether's Avatar
ether
removing the cup holder allows access to a bolt for removal of the lower finisher allowing access to the ECU..
the technosquare page has the best pics
http://www.technosquareinc.com/350ZECUremoval.htm
Old May 17, 2004 | 09:40 PM
FLZ's Avatar
FLZ
Default Techno
Great Link, Thanks, FLZ
Old May 18, 2004 | 02:24 PM
neur0sis's Avatar
neur0sis
Default Re: curious
erm, I think he is just removing it to CLEAN it, not permenantly.
Old May 18, 2004 | 03:16 PM
supra crazy's Avatar
supra crazy
do they sell the 2004 cup holders? because i want to change mine to that it feels less flimsy
sales@czp
Sep 23, 2019 03:30 PM
3vilbunny
Jul 18, 2017 05:10 PM
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
Depravity
Oct 1, 2015 04:49 PM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
