Xenon upgrade for base
Old Jul 26, 2004 | 10:01 PM
Spideynw's Avatar
Spideynw
Default Xenon upgrade for base
I tried to search and could not find what I was looking for. Can I upgrade my base model to the Xenon OEM headlights of the other models? If so, what do I need? Just bulbs, or is there a special housing, or do I need to also get a new wiring harness?
The dealership said I needed to get new headlight housings, which are $3000.00 for the set and a new wiring harness. But, as I've learned on these boards, the dealerships are full of sh$t.
Old Jul 26, 2004 | 10:06 PM
mrZeee's Avatar
mrZeee
that would possibly be the "easiest" way to go...or you could cut/modify your housing to get everything you will need to upgrade...its been done...search for HID instead of XENON...you might have better luck!
Old Jul 27, 2004 | 01:16 AM
juhko's Avatar
juhko
A local Z buddy of mine just did this.
Unfortunately, I wasn't able to help out as I was out of town but he said he followed something along the same lines as is covered here:https://my350z.com/forum/showthread....threadid=52790
Make sure you get D2R and not D2S bulbs.
Good luck!
Old Jul 27, 2004 | 01:54 AM
Mr B's Avatar
Mr B
You can actually find a H7 HID kit and just slap that in. No modifications needed and looks just fine. Housing for the bulb might be different but the projectors throw out the beam just the same.
Old Jul 27, 2004 | 03:30 PM
Spideynw's Avatar
Spideynw
HID headlights are actually illegal. Please refer to the "for off road use only" labels. This is why I am asking about upgrading to the OEM Xenon headlights. Does anyone know the answer to my questions or know of a link where the questions have already been answered?
Old Jul 27, 2004 | 06:53 PM
Jun's Avatar
Jun
Here is pretty much what you need from Nissan:
Cover - $4.74
HID ballast - $241.96
HID bulb - $172.36
Harness - $17.18
Bracket - $4.06
Total - 440.30 x 2 = $880.60 AT LEAST
If you buy this at the dealership of course it will be more.
Old Jul 28, 2004 | 05:49 AM
thunder0880's Avatar
thunder0880
Dont listen to all this bs man. Here ya go, I found this for you on ebay. This is the exact kit used on oem 350z's
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
It comes with everything you need. Plus this kit is new. Although you will still cut a hole in the round plate behind the headlights unless you want to buy one from nissan for $5. Hope this helps.
Old Jul 28, 2004 | 10:23 AM
Jun's Avatar
Jun
so that fits in the same hole where the stock HID ballasts go? same mounts and everything?
Old Jul 28, 2004 | 10:33 AM
yobri's Avatar
yobri
Wondering the same thing... awfully good price for virtually OEM...
Old Jul 28, 2004 | 01:32 PM
thunder0880
Yea same everything, upgrading to oem is cheaper than most people think, unless you get your prices from a dealer!
Old Jul 28, 2004 | 01:40 PM
juhko's Avatar
juhko
If you do go for it, be sure to write it up for anyone else that might find themselves in your situation...
Old Jul 28, 2004 | 03:32 PM
Spideynw's Avatar
Spideynw
PHILIPS HID BALLAST WITH 4300k PHILIPS D2R BULBS KIT
THE BEST KIT FOR REFLECTOR HEADLIGHT
Old Jul 29, 2004 | 02:15 AM
MY350Z.COM's Avatar
There are a few kits being offered by our sponsors in the Vendor Classifieds forum.
http://www.Gruppe-S.com
http://www.350zforums.org/store
have kits. You'll have to call.
Victor
Old Jul 29, 2004 | 07:19 PM
REDZED's Avatar
REDZED
Its an easy mod with many aftermarket kits available that supply a HID lamp with a base that fits the existing housing, and a seperate box that contains the electronics/igniter. Apart from bing a bit of a pain getting to the lamp covers ( under the wheel arches ) there's no rocket science to it. Took me about 3 hours to do it to the standard I expect ( good wiring, proper mounting etc ).
The reults - great ( should be stock fitting ).
Old Aug 9, 2004 | 06:32 PM
jor8888's Avatar
jor8888
http://www.importhookup.com/ is where most ppl got their after market H7 HID kit for the base model. I bought the 6500k kit and the color is awesome but still not purple enough for the cops to stop me. U will need new housing if u are planning to buy used 350z hid because the base housing is diff than the hid housing that holds the bulb.
My hid compare to acura hid.
Old Jan 18, 2005 | 09:59 AM
topdaytrader's Avatar
topdaytrader
check out http://www.motionr.com
Here's Testimonials from MotionR bulbs users:
http://hyundaiperformance.com/forums/topic.php?t=8938
http://www.cardomain.com/member_pag...?page_id=374204
http://www.toyotanation.com/forum/s...&threadid=19415
http://www.sonataspeed.com/yabbse/i...g17225#msg17225
http://www.j-body.org/forums/read.p...207861&t=207861
http://www.topendmotorsports.com/me...?searchid=11937
http://www.toyotanation.com/forum/a...ic/19071-1.html
Old Jan 18, 2005 | 10:16 AM
GQ 350z's Avatar
GQ 350z
I'm about to buy them from motion-r, just wondering if they would match my superwhite led's. I'm trying to get the 6000k--that price can't be beat.
Since I have oem HID's, I'm sure all it is is getting behind the housing and putting this bulb in?
Ravi
Old Jan 18, 2005 | 12:42 PM
GQ 350z's Avatar
GQ 350z
I was told to get D2s bulbs from motion-r. Is this true? or should I stick with D2r?
I am not sure, so could someone tell me what I will need for this to function properly? I have OEM hid's.
ravi
Old Jan 18, 2005 | 01:01 PM
xjerseyzfinestx's Avatar
xjerseyzfinestx
Default ...
o please just buy some h7 hid kit and slap them on who gives a sh*t if there illegal or not lol...
Old Jan 18, 2005 | 01:15 PM
doodeitstom's Avatar
doodeitstom
Default Re: ...
I agree. If a cop pulls you over. Tell them it came from the factory. Unless you get pulled over by a cop who is a nissan enthusiast, then you shouldnt have a problem.
Make sure its not over 4k
