Harnesses
Old Jul 28, 2004 | 09:52 AM
mofoz's Avatar
mofoz
Default Harnesses
Anyone have either of the nismo harnesses listed on performancenissanparts.com? Just wondering on what you thought of them, or any other harnesses you have. Are there any that mount without a harness bar?
Thanks,
Bill
Old Jul 28, 2004 | 01:54 PM
Moroccan_Mole's Avatar
Moroccan_Mole
there is no safe way to mount a harness in the z without a harness/roll bar.
other harness, sparco/sabelt/williams/takata ... personally i will use takatas, bright green jdm goodness but they're entirely way too expensive; retail is $450ish a piece.
Old Jul 28, 2004 | 02:10 PM
EnthuZ's Avatar
EnthuZ
I couldn't agree more!
May I suggest a BCR Harness Bar?
Old Jul 28, 2004 | 02:35 PM
Moroccan_Mole
a little off topic ...
are you going to be offering the bar powdercoated in different colors (black/body matched, etc)
Old Jul 28, 2004 | 02:36 PM
spdu4ia's Avatar
spdu4ia
i have sparco 3 points and i mounted them to the floor in the rear below the STB. people say dont do it this way, but when the belt comes over the speaker pods behind the seat and through the headrest it makes it a perfect horizontal line (which is what is recomended).
Old Jul 28, 2004 | 02:57 PM
EnthuZ's Avatar
EnthuZ
Those are only support points.....NOT load bearing!
With a BCR harness bar ALL the load is into the OEM shoulder belt mounting points.
You have created an inverted "V", which will create spinal compression.
Moroccan_Mole, Yes, I will offer different colored powdercoating, but body color matching will only be available though Zpresence.
BTW, I have black & silver available for shipment today.
PM for specifics.
Old Jul 28, 2004 | 03:03 PM
Moroccan_Mole
wish i could afford it right now
Old Jul 29, 2004 | 02:17 AM
MY350Z.COM's Avatar
FYI
The authentic NISMO harness is made by Willans.
Make sure you don't get a cheap eBay knockoff.
The NISMO is really nice, it has a central lock mechanism like one of the Scroth units.
Old Jul 29, 2004 | 06:38 AM
fairladyz33's Avatar
fairladyz33
My takata harness.
pretty good, very tight, I cannot even turn my body to get something from the center console.
Old Jul 29, 2004 | 06:39 AM
fairladyz33
mounting point,
BMW driving school instructor approved.
Old Jul 29, 2004 | 01:26 PM
EnthuZ's Avatar
EnthuZ
IMO, BMW inspectors don't know sh*t!
PCA tech inspectors REQUIRE a harness bar or an equal bar in a roll bar/cage with competition belts.
Read the instructions from Sparco or Schroth harness's for KNOWLEDGEABLE info on belt mounting.
I've had enough back problems that I refuse to compromise my belt installation.
Old Jul 29, 2004 | 05:27 PM
MY350Z.COM's Avatar
Originally posted by fairladyz33
mounting point,
are you serious? that cover looks like it could pop out so easily with little pressure. even if it is held on strong that plastic could break off.
Old Jul 29, 2004 | 05:46 PM
spdu4ia's Avatar
spdu4ia
its not bolted to the plastic, its bolted to the metal underneath i imagine
Old Jul 29, 2004 | 05:57 PM
PhoenixINX's Avatar
PhoenixINX
Even then, I could bend the metal underneith with my hands...
TOO SOFT BRO!
Time to rethink that.
Old Jul 29, 2004 | 10:39 PM
mofoz's Avatar
mofoz
ya i dont think it would be smart to mount it back there. it may seem fine, but if you hit a car going 40, your gonna be through the windshield.
Old Jul 30, 2004 | 01:12 AM
PhoenixINX's Avatar
PhoenixINX
Uh huh.
Old Jul 30, 2004 | 06:47 AM
fairladyz33
Pop opne that cover and you will see what's underneath...
Old Jul 30, 2004 | 07:11 AM
mofoz's Avatar
mofoz
well i guess you could have had something fabricated and welded some tubular steelto the frame back there,and then welded the plate to that. but still, i would go with a bar that mounts using the stock points.
Old Aug 6, 2004 | 06:45 PM
mofoz's Avatar
mofoz
Anyone use Sparco harnesses? And is there any reason nismo is better than sparco? The nismo are alot more expensive, but they seem to be oh so sexy.
Old Aug 8, 2004 | 07:32 AM
Brandon@Forged's Avatar
Brandon@Forged
Forged Internals.com
I was considering where to put a harness bar. I did finally find a roll cage made by Cusco that looks like something I wanted. Look at these MS Paint pics and tell me which one you guy's think would be safest? The BCR harness is too high imo and obstructs view. There are a total of 4 different lines, I would only use one of those. So which one looks the safest/strongest/best/etc?
