Nismo body kit & suspension (from Performance Nissan) installed...
Just got the Nismo suspension, Nismo side skirts & rear unders installed Friday. The front lip will be installed next weekend. The suspension will lower the Z 3/4 - 7/8" after it settles in a few weeks - right now it's dropped an 1/8" in the 2 days it's been on. The difference in handling was immediate after install - a little stiffer (what I wanted), no more body lean or nose diving - pretty cool feeling! If you were going to track your Z, I would recommend an adjustable setup - Tein, for example - but for me as a daily driver, the Nismo kit is perfect - improved steering response, a little more firm ride, and a subtle drop that keeps the alignment issue in check. The install was pretty straight forward - simple bolt off, bolt on. The book time is approx. 4.2 hours, but my tech had it done in 2 hours. You need to align the car both after install & after 3-4 weeks (after it settles).
As for the Nismo side skirts & rear unders, again a pretty straight forward install - the side skirts were a piece of cake. The rear unders & the front lip (when it is installed next weekend) takes a little more guts - gotta drill a few oblong holes in both the front & rear bumpers (yikes!). After making sure the enclosed template is taped on correctly, it is pretty simple. Was torn between 2 pretty subtle kits - Nismo & Veilside - but decided to go for the Nismo due to the great prices Perfromance Nissan is offering (Thanks Jason & Jeff!!).
Here's a couple shots for now. Will post more next weekend after the front lip goes on. Gonna keep the OEM Niisan rear spoiler on - I like the "low-slung" effect - seems to compliment the lower look the aeros add.
Sweet.......congrat's Jack. It's going to be sick ride when you get done.
By the way finally got my Evostyle silver turn signal bulbs in and installed Sunday. Your right it looks so much cleaner.
Originally posted by Strife350z
the sides are very agressive looking on the USDM... is there a difference in the appearance of the front lip?
