Question?how Do You Remove The From Stock Grill?
Old Oct 27, 2004 | 10:05 AM
nexstage350's Avatar
nexstage350
Question Question?how Do You Remove The From Stock Grill?
I am planning on taking off the front stock grill off. i have plans to put a turbo/w IC. i want to have the IC clearly visable. how do you remove that black stock grill off? do u cut it off? or can you snap it off some how. if there is any out there with some info please help. thanks!
Old Oct 27, 2004 | 12:21 PM
mgl's Avatar
mgl
you need to cut it out.
i used a hacksaw and dremel.
Old Oct 28, 2004 | 05:24 AM
nexstage350
mannn i that is what i was afraid of. is it pretty easy to do?? if i do it i just want to make sure i don't make it look crappy. do you have any tips? hey thanks for your response.
Old Oct 28, 2004 | 07:27 AM
mgl's Avatar
mgl
yeah, it was fairly simple.
i suggest you wear some protective eyewear, as little black plastic shavings go everywhere.
Old Oct 28, 2004 | 08:37 AM
teh215's Avatar
teh215
I cut mine out in about 2 minutes with a sharp utility knife and there was no mess to clean up and no ragged cut line.
Old Oct 28, 2004 | 11:27 AM
nexstage350
thanks for the response, another quick question. where did you start ur cut? i have not taken a really good look of it up close, but i plan on doing it sometime this weekend. i just wanted to get a real good idea first b4 i start. thanks again
Old Oct 28, 2004 | 11:28 AM
nexstage350
by chance where did you start ur cut? i plan on doing it really soon and i want to bling out my intercooler. thanks again for your response.
Old Oct 28, 2004 | 11:38 AM
teh215's Avatar
teh215
In the middle of the top of the grill IIRC. Once you get the knife through the plastic and start cutting you should be able to feel a path around the grill where the knife encounters much less resistance. I am assuming that the plastic this thinner there. Just follow that around the grill and it will be out in no time.
Vigman
Nov 17, 2015 04:34 AM
Paul.
Oct 16, 2015 07:34 PM
FromGtoZ
Sep 20, 2015 03:41 PM
etong
Sep 10, 2015 06:14 PM
