Block Deck
Old Dec 5, 2004 | 12:52 PM
XxBoostdxX's Avatar
XxBoostdxX
Default Block Deck
OK i couldn't find this but i may not be searching for the right things but anyway...is the Z's block open-deck, closed-deck, or semi-closed deck?
Old Dec 5, 2004 | 01:02 PM
t32gzz's Avatar
t32gzz
Open deck, but not like the Hondas. It is only open about 2.5" deep.
Old Dec 5, 2004 | 07:02 PM
ss350's Avatar
ss350
what do all these terms mean: open-deck vs. closed deck?.....
Thanx in advance
Old Dec 5, 2004 | 08:18 PM
Sharif@Forged's Avatar
Sharif@Forged
Forged Performance
Open deck means the cylinder walls are not solid all the way the block. With an open design, the cylinder wall is bathed a channel of coollant...hence...open deck...think of it like a moat around a castle.
In a closed deck, the cylinder bore is created from the block....so its solid...no moat.
Old Dec 6, 2004 | 08:42 AM
ss350's Avatar
ss350
So the advantage of open deck blocks is that they have better cooling capabilities but result in a decrease in strength. Is it possible to convert an open bloack deck into a closed deck? I always read about people talking about doing it to the VQ, but it doesn't seem like it would be an easy task.
Old Dec 6, 2004 | 08:45 AM
SilverSellout's Avatar
SilverSellout
AEBS sleeves would convert it to a closed deck.
Old Dec 6, 2004 | 11:36 AM
Sharif@Forged
Forged Performance
Correct....you can resleeve an open deck design by removing the stock cylinders and replacing them with cast iron sleeves. Some are vented slightly for coolant...others are solid.
m_0g
Jun 3, 2021 10:05 AM
sherm
Apr 11, 2020 05:21 PM
3vilbunny
Jul 18, 2017 05:10 PM
bryanlam199
Sep 24, 2015 04:04 PM
